Philips 42PFL9703D/79 LCD TV Not powering up.
  • notallbad
    • Oct 2012
    • 1190
    Re: Philips 42PFL9703D/79 LCD TV Not powering up.
    Hi
    Do keep us posted of developments.
    Not sure the 'Re-work' is applicable in your case but really need to compare the board schematics against the voltage readings to determine.
    The diodes and mosfets can be tested, but would think they would be either good or completely dead rather than intermittent faulty which is the problem you are having.
    Have a good vacation, see you when you get back!!!
    • Smithy79
      • Mar 2013
      • 12
      G'day all,
      I'm back from holidays, hope you are all well.
      Since being home I've had time to do some repairing/ investigating.
      I replaced the 2 capacitors as per attachment in post #14 in this thread, and carried out the rework as per the attachment in post #20.
      I also resoldered all the larger joints such as the transformer joints, large cap joints and any that looked like they'd 'sweat'.
      The TV seems to be working fine now. It turns on from the on/off switch without any errors, and also turns on from standby mode as well.
      I also took the voltage readings again as I had missed a couple from each ribbon connector.
      Here are the results as follows;
      -12
      0
      +12
      +12
      +12
      +12
      0
      0
      0
      0
      +3.4
      0
      +1.6
      +1.1
      +2.58
      0
      0
      +12
      +12
      Cheers for everyone's input on this issue,
      If there is anything else you could recommend it would be much appreciated.
      I appreciate everything you guys have done to help me.
      Graeme
      • notallbad
        • Oct 2012
        • 1190
        Glad to hear back from you, hope all is well!
        It might be worth just using the Tv as normal over the next few weeks and pay attention to any abnormal behaviour, just in case the symptoms come back.
        Your findings will always be here for reference at a later date if similar problems occur and you'll have these notes as a starting point.
        If its working theres not really a lot more you can do other than enjoy Tv viewing.
        Still, it may be worth making a note of the voltages with the Tv in standby, if you do come back in a few weeks/months with the same/similar fault then chances are the Tv won't be powering on, stuck in standby, so knowing what the voltages should be (when it is working) would perhaps help you in future troubleshooting. Update here those voltages for your ref and ours to assist later, if need be.
        • vr2yxt
          • Jan 2017
          • 7
          • China
          I have the same problem and follow post #14 to replace the capacitors 100nF (2179) and change 22nF to 47nF(2165), no other component need to replace. My TV is working normally. Thanks.
          • Ozhammer
            • Mar 2017
            Hi Graeme, I am having exactly the same issues with my 47PFL9703D TV as you did and would like to try to get it fixed if at all possible.
            As a new forum member, I cannot apparently access the personal e-mail system, so I though the best way to reach out to you would be by posting a reply on this thread.
            I would like to try to get one of my local TV repairers to sort the problem out but I would obviously be likely to have a far greater chance of success if I could give them some advice on what to look at and your experience would therefore possibly be the best way to do that.
            If you could possibly contact me via the e-mail system and let me have any information that you think might be helpful, that would be hugely appreciated.
            Thanks in advance for your help with this.
            Rgds
            Mark
            • Jeroenkwb
              • Dec 2017
              • Netherlands
              #26
              I'm new to this forum, came across it while searching for a solution for the same problem as mentioned above. I have disassembled my tv, and disconnected the power board. When I turned it around I saw that one of the connections of the inverter transformer on the top left is a bit black. I attached a photo. Do you think the transformer is defect or is it repairable ?
              Thanks in advance.
              Jeroen
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                #27
                I would take a small wire brush and clean the joint and then remove as much of the lead free "solder" and then re-solder it with good 'ol fashioned lead and tin solder.
                You can also use a piece of copper wire to repair the trace if it burned through.
                Touch up all the joints that you can, especially The ones that are on parts attached to heatsinks.
                • ph445
                  Philips 40PFH6510/88 not powering on
                  by ph445
                  I have a Philips 40PFH6510/88 TV which is not switching on. No no standby led, no nothing. There was no bang, no smoke, it was simply switched off and next day it did not switch on.
                  I got the power PCB out and visually checked it, I did not see anything unusal on it, the fuse is OK and no cracked, burned components on either side, capacitors looks OK to me.
                  Both big 450V capacitors are charging up to around 330V but on the secondary side I can't get any reasonal voltage on any output pins. Most are around 0.2-0.3 V. (not sure which one is standby,...
                  10-23-2023, 08:00 AM
                • Protker
                  Philips 47PFH4109 blinking 2 times when powering
                  by Protker
                  Hello!
                  So i have a Philips 47PFH4109, and when i powering on the tv just blinks once, then after a 2 seconds blinks again, and does not turning on.
                  I mean i measuring voltages such like 30V on the leds and the 12 volts on the other panels, which seems to be okay.
                  I checked the backlight no issues with the leds.
                  I checked every component such as all the mosfets, all the diodes, i dont see any bad capacitors (unfortunatelly i only can measure up to 200uF).
                  I even took out the LD7591 chip and without it doing the same as before.
                  Im just seeking for advice,...
                  12-23-2021, 12:33 PM
                • G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                  by G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                  It does power up when pressing the power button.
                  I already try the power button while plugin the plug with no result.
                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                  Could this be an PSU or eMMC issue ?
                  07-19-2025, 03:43 AM
                • janos6662000
                  Philips 47PFS7509/12 LCD TV problem
                  by janos6662000
                  Hi
                  I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                  When i applied cable signal to check image, i had normal picture, but TV was restarting.
                  I downloaded original firmware and applied the update, but the problem remained.
                  From a colleague i received a "factory package software" which is a lot bigger.
                  I made another firmware update, but still did not solve the problem.
                  Somewhere on the way the error got worse, because at the moment the...
                  08-12-2025, 12:54 PM
                • aidanmo
                  Philips 43PUS7506/12 - Loud blown out sound
                  by aidanmo
                  I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                  I thought maybe the speakers got damaged, so I replaced them - no dice.
                  • Using the internal speakers, it always happens.
                  • Using the headphone jack, it never happens.
                  • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                  02-28-2025, 03:13 PM
