Dmtech lm37xty lcd
  • joehezzer
    • Jul 2012
    • 251
    • England
    Re: Dmtech lm37xty lcd
    no it was a hair lol i did remove it lol
    • joehezzer
      • Jul 2012
      • 251
      • England
      ok i noticed some burning under a fet the big solder joint in the middle
      • Aidso
        • Apr 2013
        • Ireland
        Hi there did you get this fixed? What was the fault.
        Cheers
        Aidso
        • notallbad
          • Oct 2012
          • 1183
          Sounds like the fault lies on the Main A/V board, no 'Power On' signal.
          Check some of the voltages on the various regulators on the Main A/V bd.
          • joehezzer
            • Jul 2012
            • 251
            • England
            Update: on the board, found a new board but don't have the cash to buy at mo
            • joehezzer
              • Jul 2012
              • 251
              • England
              #26
              ok got the cash, bought/replaced and it works a treat
              • MisterAIL
                PS5 digital / No Power / No Beep / Good power supply
                by MisterAIL
                Brought a non functionnal PS5. Apparently only a bad PSU...
                No beep, nothing.
                After some tests i found this :
                - PSU is fine (12 volts stable)
                - 12 volts line is shorted
                - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                - By the way, nothing change. No signal, no power, no beep.
                Mesuring all rails with my workbench psu (12 volts input)
                - 0.00 amp drawing
                - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                03-12-2024, 03:24 PM
              • BTubbs200
                Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                by BTubbs200
                Dell Latitude 5420 P137G
                Board: LA-K491P REV A01
                I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                Board seems to have no shorts, all power rails are fine and show high resistance.
                When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                01-24-2025, 08:15 PM
              • AlexVG
                JBL PARTYBOX 1000 NO sound NO 50V
                by AlexVG
                Hi, I would like to share my experience...
                So, I came across with common problem - no 50V on PSU 40-PF0750-PWD1G
                L6566B was burned. Between pin 7 and GND were short circuit. I replaced L6566B with a new one, but it gave me nothing. However, it started if I touched pin 16 with multimeter probe. Obviously the protection is triggered.
                If we look at the L6566B datasheet, we will see that to deactivate the protection (AC_OK), is enough to exceed 0.450 volts.
                In my case, I have had 0.632 volts. This is enough at the first glance. But on the oscillogram on pin 16, I observed noise...
                03-11-2025, 06:55 PM
                MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
                by sam_sam_sam
                I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
                I open it up to find non brands name capacitors in it
                I am not sure how this switching power supply is set up
                Could someone please explain how this power supply works
                Here is the capacitor ESR results
                (1) 47uf@50 volts 0.46
                (2) 47uf@50 volts 0.45
                New 47uf@50 volts 0.35
                (1) 100uf@25 volts 0.34
                (2) 100uf@25 volts 0.35
                New 120uf@50 volts 0.08
                (1) 220@25 volts 0.13...
                10-21-2018, 10:02 AM
                I am looking for a transformer secondary of 60 volts @ 30 amp
                by sam_sam_sam
                The primary voltage is 480 single phase the second voltage needed is 60 volts
                Now it could be 30 volts 0 volts 30 volts preferred
                Or it could be 60 volts 0 volts 60 volts and just use one side of
                Output amp need to be at least 30
                Dose anyone know where I can find one
                This is what is the device I am working on
                The problem with this one is that it is over heating and smelling like it is over heating
                When it has a load on it...
                07-01-2020, 08:14 PM
