Dmtech lm37xty lcd
  • joehezzer
    • Jul 2012
    • 251
    • England
    Re: Dmtech lm37xty lcd
    no it was a hair lol i did remove it lol
    • joehezzer
      • Jul 2012
      • 251
      • England
      ok i noticed some burning under a fet the big solder joint in the middle
      • Aidso
        • Apr 2013
        • Ireland
        Hi there did you get this fixed? What was the fault.
        Cheers
        Aidso
        • notallbad
          • Oct 2012
          • 1190
          Sounds like the fault lies on the Main A/V board, no 'Power On' signal.
          Check some of the voltages on the various regulators on the Main A/V bd.
          • joehezzer
            • Jul 2012
            • 251
            • England
            Update: on the board, found a new board but don't have the cash to buy at mo
            • joehezzer
              • Jul 2012
              • 251
              • England
              #26
              ok got the cash, bought/replaced and it works a treat
              • u666sa
                HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                by u666sa
                Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                Platform: ipa32 la-m024p rev 1b
                Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                I found a short on the other side:
                Yesterday, 05:03 PM
              • supermattch
                HP 15dy-2021nr wont power on mystery volts
                by supermattch
                Hi everyone.
                I am diagnosing my personal laptop, because it wont power on and no leds light up.
                At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                09-23-2025, 12:13 PM
              • MisterAIL
                PS5 digital / No Power / No Beep / Good power supply
                by MisterAIL
                Brought a non functionnal PS5. Apparently only a bad PSU...
                No beep, nothing.
                After some tests i found this :
                - PSU is fine (12 volts stable)
                - 12 volts line is shorted
                - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                - By the way, nothing change. No signal, no power, no beep.
                Mesuring all rails with my workbench psu (12 volts input)
                - 0.00 amp drawing
                - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                03-12-2024, 03:24 PM
              • Mcfeetroy
                Fishing bite alarm drains battery
                by Mcfeetroy
                Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                08-01-2025, 03:52 AM
              • BTubbs200
                Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                by BTubbs200
                Dell Latitude 5420 P137G
                Board: LA-K491P REV A01
                I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                Board seems to have no shorts, all power rails are fine and show high resistance.
                When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                01-24-2025, 08:15 PM
