Dmtech lm37xty lcd
  • joehezzer
    • Jul 2012
    • 251
    • England
    Dmtech lm37xty lcd
    OK so i got given a dmtech lcd screen,i turns on to stand by the red light comes on for about 5 seconds then goes out. when i first got the set it came on for about 5 mins then turned off. i took it apart and started to have a fiddle i thought to start i would test the supply and while i was there i changed a few caps marked red. i cannot see any damage to the board
    ok so i started to test the supply with my meter, con 1 i have been testing
    i got 5 volts where it said 5 volts and 12 volts where it said 12 volts etc. the only part i never got anything on is where it says power, got no reading at all.my question is i am right at thinking i should be getting a reading there. thanks in advance
  • joehezzer
    • Jul 2012
    • 251
    • England
    Re: Dmtech lm37xty lcd
    • joehezzer
      • Jul 2012
      • 251
      • England
      • joehezzer
        • Jul 2012
        • 251
        • England
        Any Anybody had any dealings with this product
          Never worked on one of these myself.
          I would look at the mainboard myself. If PSU is giving 5V/12V it's probably OK.
          • joehezzer
            • Jul 2012
            • 251
            • England
            Cheers tom will have alook this week at some point cheers
            • joehezzer
              • Jul 2012
              • 251
              • England
              i have no power here, at the other end i just says on/off. this goes another board, i will post a pic when i get chance
                It's most likely the power on signal. Does it change at all when the TV's plugged in?
                • joehezzer
                  • Jul 2012
                  • 251
                  • England
                  no nothing at all
                    Do you get a 24V output?
                    • joehezzer
                      • Jul 2012
                      • 251
                      • England
                      i get 24volts where it says i should be getting 24volts and 5 volts where it says 5 volts.on the psu
                      • joehezzer
                        • Jul 2012
                        • 251
                        • England
                        it does seem like the psu is working as i seem to have all the correct voltage except at that point on the psu
                        • joehezzer
                          • Jul 2012
                          • 251
                          • England
                          i wonder if i have a dry joint somewhere
                            OK, can we get a look at the main board?
                            • joehezzer
                              • Jul 2012
                              • 251
                              • England
                              i will have a better look tomoz after work and i will post some pics cheers tom
                              • joehezzer
                                • Jul 2012
                                • 251
                                • England
                                Ok just been taking the lcd screen apart I have got to the T con driver board would that be the main board
                                • joehezzer
                                  • Jul 2012
                                  • 251
                                  • England
                                  ok this is the view of the back of the set
                                    Main board's the one with the video inputs on it.
                                    • joehezzer
                                      • Jul 2012
                                      • 251
                                      • England
                                      ok main board i cannot see any burning or bad caps
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        ^ Looks like a crack in one of the chips (large square one, about right-center); is it the chip, or is it the camera/other particles causing the 'crack' to show on the chip in the picture?
                                        Muh-soggy-knee
                                        • supermattch
                                          HP 15dy-2021nr wont power on mystery volts
                                          by supermattch
                                          Hi everyone.
                                          I am diagnosing my personal laptop, because it wont power on and no leds light up.
                                          At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                                          Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                                          09-23-2025, 12:13 PM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
                                        • Mcfeetroy
                                          Fishing bite alarm drains battery
                                          by Mcfeetroy
                                          Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                          08-01-2025, 03:52 AM
                                        • BTubbs200
                                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                          by BTubbs200
                                          Dell Latitude 5420 P137G
                                          Board: LA-K491P REV A01
                                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                          Board seems to have no shorts, all power rails are fine and show high resistance.
                                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                          01-24-2025, 08:15 PM
                                        • AlexVG
                                          JBL PARTYBOX 1000 NO sound NO 50V
                                          by AlexVG
                                          Hi, I would like to share my experience...
                                          So, I came across with common problem - no 50V on PSU 40-PF0750-PWD1G
                                          L6566B was burned. Between pin 7 and GND were short circuit. I replaced L6566B with a new one, but it gave me nothing. However, it started if I touched pin 16 with multimeter probe. Obviously the protection is triggered.
                                          If we look at the L6566B datasheet, we will see that to deactivate the protection (AC_OK), is enough to exceed 0.450 volts.
                                          In my case, I have had 0.632 volts. This is enough at the first glance. But on the oscillogram on pin 16, I observed noise...
                                          03-11-2025, 06:55 PM
