Baird X37DTV stobe Backlight issue
  • jennybn
    • Sep 2013
    • 3
    #41
    Re: Baird X37DTV stobe Backlight issue
    i was going to reply much earlier, but i had a visitor.
    the current cap is 1500uf 16v, it should be a 1000uf 16v.
    i actually heat the set up at the 150uF 400v for the voltage to stabilise, which i presume is the primary side.
    • baddesley
      Engineer
      • Dec 2012
      • 55
      This is exactly the same problem I have with one of these; an X42DTV.
      I have replaced all of the caps in the power supply and the the two in each inverter (the only ones that were at all bulging), but it's stil the same - flickering/strobing on the screen, no sound or video, stops strobing after a while.
      The 5V and 16.5V rails are fine, the 12V rail is down at approx. 8V, but I don't think it's the PSU at fault, most likely the main board, as Wreksta says. I tried disconnecting the power to this board, but the set then fails to power up, obviously due to a necessary feedback loop.
      Anyone managed to find the actual cause, or a circuit diagram for these?
      • Cornito
        Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
        by Cornito
        Hello Team,
        I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
        Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
        Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
        08-08-2024, 08:09 AM
      • cheebster
        iPad Pro 12.9 5th Gen Backlight Issue
        by cheebster
        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
        Anyone...
        05-20-2025, 09:17 AM
      • Acnologia
        Lenovo Thinkpad T540P - Showing at 14" inch but NOT at 15.6" inch (Backlight issue) ?
        by Acnologia
        Hello to all members of badcaps.
        Another brainstorming that i have been messing with for months as a side project.
        Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
        I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
        Step 1.
        Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
        Machine > Doesn't give display it's really dim.
        Step 2.
        Use the same...
        11-05-2025, 04:02 AM
      • Cornito
        TCL 65C715 backlight issue
        by Cornito
        Hello team,
        I'm back with another topic.
        It's a 65C715 TCL tv with backlight issue.
        But the problem is a bit strange.
        When I took this tv from the marketplace backlight didn't work but picture was ok.
        Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
        Putting all back together the tv worked fine for weeks. => Contact issue??
        Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
        06-09-2024, 02:24 AM
      • shellybelly
        Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
        by shellybelly
        Back Story
        I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
        So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
        08-27-2023, 10:40 PM
