baird lcd tv no backlight
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • jimbofz
    lg 32LC46 backlight inverter board fault
    by jimbofz
    Hi this oldie had no backlight .after replacing caps on 24v rail ,
    still no b/l this uses inverter type:1315 B1-16A,
    im sure ive come across the same inverter in a samsung possibly le32r88bd ?
    all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
    this allows protect to be temporary overridden.
    b/l now comes on
    but the left hand side of pic is gradually darker than the right side
    i have the cct for the tv
    but it does not have inverter cct.
    i opened it up to inspect the ccfl tubes
    and they dont have any...
    12-19-2021, 06:58 AM
  • canadaboy25
    LG Flatron 24EN33TA No Backlight When Cold
    by canadaboy25
    I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
    I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
    03-07-2023, 12:23 AM
  • fharris1977
    Hitachi L40C205 lines in display after Backlight Inverter Repair
    by fharris1977
    Hello. I replaced the backlight inverter on this set for a customer and there are lines horizontally and vertically on the display. They show up sometimes I guess depending on the color of the background screen (will include pictures). The customer swears the lines weren't in the screen before the backlight inverter went out. I thought it may be a bad T-con board at first but this set has no T-con board. So if anyone can help, do you think my problem is in the mainboard, the backlight inverter I replaced, the power supply, a cable, or the display (which means the customer is lying or just didn't...
    07-31-2020, 02:32 PM
  • Dreadnought
    L40DIGB20 Logik 40" inverter/backlight issue.
    by Dreadnought
    Hi. Firstly I apologise if I break any forum unwritten rules, as I'm new here. I've used badcaps for advice in the past, but I've only just joined. I'm self taught, so I don't have anywhere near the knowledge that some of you guys have, but I can only hope to keep learning and get there one day.
    Anyway, I've been working on a TV recently. It's the one listed in the title. Logik L40DIGB20. It powers on fine, with the standby light turning blue as it should. The backlight turns on for a second, then goes off. Using a flashlight, I can see an image on the screen. The power supply is fine,...
    02-08-2021, 12:28 PM
