Fuse blows immediately when I plug in power cord into my Vizio VW42LFHDTV10A TV Help!
  • troydi40
    • Feb 2013
    When I put a new fuse into the Power Supply Unit board in my Vizio Model:VW42LFHDTV10A TV, when I plug in the power cord, the fuse blows immediately. I measured the electricity coming out of the power cord (tried several power cords too) and it seems to be fine. Can anyone give me an idea where to look? The PSU board looks fine, but I know looks can be deceiving. Is it safe to say I need a new PSU board? or can anything else in the TV blow a fuse? Your help is very much appreciated!
  • troydi40
    • Feb 2013
    Re: Fuse blows immediately when I plug in power cord into my Vizio VW42LFHDTV10A TV H
    Oh, I also get no lights, no picture, no power of any kind when this happens. The fuse blows to fast.
    • mariushm
      • May 2011
      • 3799
      Follow the trace going from the fuse to the insides of the board and check each component touching that trace from the fuse with a multimeter. Set the meter on continuity and touch component leads with both probes to see if they're shorted (with power to the monitor off)
      Measure it with the continuity function of your meter and see if the component is shorted. Check diodes to see if they conduct in both directions.
      If you still can't determine the component with issues, see what voltage is supposed to come on that trace where the fuse blows, then get an adjustable power supply with current limit function, set the current limit to something low like 100-200mA and connect the power from the power supply to the fuse side with the trace... see what component that's on the trace is much hotter than the others and then remove the power and test that component.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Welcome to the forum-
        We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
        Examples of what is needed
        https://www.badcaps.net/forum/attach...7&d=1280167246
        https://www.badcaps.net/forum/attach...6&d=1280167246
        https://www.badcaps.net/forum/attach...4&d=1280167246
        It will be useful if you can say a bit about yourself - skills tools etc.
        • BlackScreen_22
          Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
          by BlackScreen_22
          Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
          Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
          I had no problems connecting mosfets and capacitors,...
          08-27-2024, 12:46 PM
        • corrize
          A funny fuse story – Lumix LX100 II
          by corrize
          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
          10-19-2023, 09:58 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Michale32086
          LG 60LN5400 Blows TCON Fuse
          by Michale32086
          I could have sworn I posted about this before, but I can't seem to find the post..
          To whit..
          I have a 60LN5400 that came in.. Backlights work fine.. No display..
          Traced the problem to the TCON board.. Blown fuse..
          Replaced the fuse.. Blows again.. Replaced the fuse again... This time it fries the marked part on the Main Video board...
          Got a new Main Video Board.. Replaced the fuse on the TCON..
          The fuse is fine and the backlights come on fine if I don't have the cellophane connectors from the TCON to the...
          10-30-2019, 09:21 AM
        • jesterace
          Samsung UE46ES8000 Blown fuse but no other signs of short
          by jesterace
          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
          09-11-2024, 03:14 PM
