need help 10 flash. unhooked ss board get 6 flash. need flash codes for this model.
panasonic tc42pc2
Re: panasonic tc42pc2
still trying to upload it.Attached Filesif you find these attachements useful please consider making a small donation to the site
Here's the alternate LCD version
Something quick and easy to check would be the resistance on both the VS inputs SS & SC (SN? whatever it's called) see if any short or low resistance.Attached Filesif you find these attachements useful please consider making a small donation to the site
by ekozeko333Hi all,
🧠 What I’ve Done So Far
Flashed...-
Channel: BIOS Requests ONLY!
by corrizeHello, I'm stuck in troubleshooting…
The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
When I press the flash button, it's detected by the system, flash icon appear on LDC display.... -
I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...-
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... -
by fixxy88Hi everyone. I've been given a dead Pana 55DX600u that I hope to save from landfill. I suspect the tcon board or UC1 on that board.
Set will flash green led and attempt to start, backlight gives a brief flash then set shuts down and red led flashes slowly. Voltages out of PSU look ok. TCon board gets 12v at fuse when attempting to start and 3.3v on L1 but main IC gets warm very quickly (heatsink/cover removed, felt with back of hand) during the second or two the 12v is applied before PSU shuts down. TVS diodes on lvds input lines are not shorted, no caps appear to be shorted. ... - Loading...
