Can two T-con boards V420H1-C07 be different?
  • snake91876
    • Feb 2013
    • 236
    The t-con board in this insignia is v420h1-c07 and was replacing with another the number on the side is D033271. The board i orederd contains the same plugs but has different components on the board. Will it still work or is the DO number the specific number. Thanks
  • high-tech
    • Sep 2010
    • 197
    Re: Can two T-con boards V420H1-C07 be different?
    Google this number D033271 and shopjimmy comes up on the search list and shows the model number of the tv and the panel number as well. check it out...
    match the numbers and connect the dots and bingo you got your answer
    • snake91876
      • Feb 2013
      • 236
      yeah i pull up the number on shop jimmy and it shows me the model tv i am working on a 47" insignia, was just wondering would a v42h01-c07 board with a different number work i have a D033271 and one a guy had for sale was a D018 something they have the same plugs but have different components on them. Is each one specific to different type tvs , just because itll plug up it probly wont work will it.
      • selldoor
        Slow Learner
        • 7870
        I believe the T-CON needs to be matched to the panel so you would need to get the panel detail off the label.
        • tibimakai
          • Jan 2012
          • 3680
          V420 it's not for a 42" screen?
          I have replaced one last week and I had to look for the D016766 number too.
          It was from a Westinghouse and I have used it in a Toshiba and it worked.
          I would probably look for one that matches the layout as well. It could be a new revision, but I wouldn't take a chance with it.
          Ask them if it's the same and if they take it back if it's not working with your setup.
          • snake91876
            • Feb 2013
            • 236
            i bought one with the same DO number they had it listed for another tv but i guess it should work.
            • selldoor
              Slow Learner
              • 7870
              For anyone following this - story continues on another thread
              https://www.badcaps.net/forum/showth...d=1#post318125
              Best not to post further in this thread
              • ugamazing
                by ugamazing
                12-17-2024, 07:05 PM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • netgearnetgear
                TCL 43S423 TCON OR PANEL FAULTY???
                by netgearnetgear
                Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                08-20-2025, 06:04 PM
