The t-con board in this insignia is v420h1-c07 and was replacing with another the number on the side is D033271. The board i orederd contains the same plugs but has different components on the board. Will it still work or is the DO number the specific number. Thanks
Can two T-con boards V420H1-C07 be different?
Tags: None
Re: Can two T-con boards V420H1-C07 be different?
Google this number D033271 and shopjimmy comes up on the search list and shows the model number of the tv and the panel number as well. check it out...
match the numbers and connect the dots and bingo you got your answer -
yeah i pull up the number on shop jimmy and it shows me the model tv i am working on a 47" insignia, was just wondering would a v42h01-c07 board with a different number work i have a D033271 and one a guy had for sale was a D018 something they have the same plugs but have different components on them. Is each one specific to different type tvs , just because itll plug up it probly wont work will it.Comment
I believe the T-CON needs to be matched to the panel so you would need to get the panel detail off the label.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
V420 it's not for a 42" screen?
I have replaced one last week and I had to look for the D016766 number too.
It was from a Westinghouse and I have used it in a Toshiba and it worked.
I would probably look for one that matches the layout as well. It could be a new revision, but I wouldn't take a chance with it.
Ask them if it's the same and if they take it back if it's not working with your setup.Comment
i bought one with the same DO number they had it listed for another tv but i guess it should work.Comment
For anyone following this - story continues on another thread
https://www.badcaps.net/forum/showth...d=1#post318125
Best not to post further in this threadPlease upload pictures using attachment function when ask for help on the repair
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
