Lg 50pc56
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Lg 50pc56
    My Tv is having a few issues had it a few years now never had a problem.
    The tv powers on seems to work fine etc but theres what i call noise/distortion like little white/green/multicoloured dots mainly show on blacks and theres also a thin red/blue line running down the middle of the screen
    The line doesn't really bother me but the noise/distortion on black/dark scenes is starting to annoy me
    any ideas on what the problem is?
    took a video best i could to show this, i have the back off already and it seems the roller fan has died too
    http://www.youtube.com/watch?v=57oJM7HlZu0
    Re: Lg 50pc56
    Very common issue.
    Line is a bad plasma panel, probably.
    The noise is known as "sparklies effect" or "maldischarge". It can be rectified only by re-programming the control board firmware, which must be done with a jig, approx £120 to buy from LG. Several members on this forum offer reprogramming services for a small fee.
    • anotherdude
      • Feb 2013
      • 488
      • uk
      Re: Lg 50pc56
      Originally posted by tom66
      Very common issue.
      care to point me in the right direction?
      take it i need to remove the control board and send it away to whoever?
        Re: Lg 50pc56
        Yep, board needs to go off to a member here. Can't remember off my head who does this but if you do some searching you'll find a few offering the service.
        • anotherdude
          • Feb 2013
          • 488
          • uk
          Re: Lg 50pc56
          postage each way at £6-10 then whatever they charge
          cheaper to get a new board or?
            Re: Lg 50pc56
            New board doesn't usually come with the upgraded firmware.
            The plasma panel begins ageing causing the sparklies, and the firmware fixes the problem.
            • anotherdude
              • Feb 2013
              • 488
              • uk
              Re: Lg 50pc56
              anyone able to point me to someone in the UK that can fix the firmware on the board, searched but found nothing
                Re: Lg 50pc56
                I have a feeling user "muskin" may do this, I think he is the person I sent my board off to last time.
                • anotherdude
                  • Feb 2013
                  • 488
                  • uk
                  Re: Lg 50pc56
                  he's not been on since december and in Hudson NC, sending a board to the US is just going to be costly
                  thanks anyway
                  • anotherdude
                    • Feb 2013
                    • 488
                    • uk
                    Re: Lg 50pc56
                    tom, found the lg jig for £50
                    just need to know where to find the firmware now really any ideas?
                      Re: Lg 50pc56
                      Here:
                      http://www.tgohome.com/ServiceManual...&Search=Submit
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        Re: Lg 50pc56
                        the lg jigs seem cheap now is the firmware free though?
                        http://www.ebay.co.uk/itm/LG-JIG-/26...item3ccee342bc
                        or build your own?
                        http://openlgtv.org.ru/forum/viewtopic.php?f=5&t=770
                        • anotherdude
                          • Feb 2013
                          • 488
                          • uk
                          Re: Lg 50pc56
                          seems that a no go still gonna cost me £70+
                          apparently you need a rs232-c cable or am i reading it wrong
                          • anotherdude
                            • Feb 2013
                            • 488
                            • uk
                            Re: Lg 50pc56
                            don't know whether to just bare with it, adjusted the POT on the back and it's cleared it up a fair bit
                            • satinser
                              • Oct 2012
                              • 214
                              • uk
                              Re: Lg 50pc56
                              Got the same problem as you had in your last post you stated you adjusted the pot on on the back and it cleared up the problem but not completely. Take it you were referring to VS pot on PSU board. Appreciate sometime has now passed. Have any issues developed after decreasing the VS voltage?
                              • MegaZAC
                                Onkyo TX-SR805 noise in one channel
                                by MegaZAC
                                Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                There's some logic behind it. As soon as I select an input I get only left...
                                04-23-2025, 10:09 PM
                              • dreamlayers
                                Weird clipping on Logitech Z-10 speakers
                                by dreamlayers
                                I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                                05-22-2025, 11:41 AM
                              • courtcircuit
                                Philips HTS8000 home cinema noise problem
                                by courtcircuit
                                Hello
                                I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                Removed each of tyhe boards
                                02-08-2025, 08:22 AM
                              • cubytus
                                Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                by cubytus
                                Hi to all,
                                I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                01-10-2024, 01:26 AM
                              • otaku_nut
                                Vizio E701i-A3 fixed but now has red vertical line
                                by otaku_nut
                                Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                                08-19-2025, 06:11 PM
