Sony 46EX400 won't turn on, 2 blinks
  • iglitare
    by iglitare
    09-04-2025, 07:13 AM
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • thelankanguy
    Sony KD-55X9000F TCON Issue
    by thelankanguy
    The TV shows a black screen with no image.
    TCON ribbon connectors were disconnected individually for image and there was no half image even.
    Later both ribbons were disconnected and TCON voltages were tested.
    12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
    There is also a short to ground in this circled inductor.
    Is this a TCON issue or something else ?...
    12-13-2024, 12:27 AM
  • GoodCapDude
    Sony XBR-75X940E intermittent 6 blinks error code
    by GoodCapDude
    Hi everyone. First post on Badcaps!
    I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
    09-20-2025, 06:07 AM
  • bbrain
    Sony KD-55AG9 TCON?
    by bbrain
    I have this problem with my Sony 55' AG9.
    It flashes 4x.
    I have found the service manual, and seems it is the TCON.
    Before I buy a TCON can someone check the vid?
    Thanks in advance!...
    09-19-2024, 10:50 AM
