Sony 46EX400 won't turn on, 2 blinks
    Re: Sony 46EX400 won't turn on, 2 blinks
    That means we cannot rely on that error code then, need to find out what trip the TV into shutdown (go into standby mode).
    But since the main board is not even sending out the T-CON on signal, then more likely to have to look at the main board next, you should be able to turn on the T-con by applying the 3.3v to the T-CON on pin also.
    • tibimakai
      • Jan 2012
      • 3680
      Any new ideas?
      • tibimakai
        • Jan 2012
        • 3680
        I have removed the black wire (T-con_on) from the PS connector and I have applied 3.2V to that pin and I have got 12.69V at the T-con 12V pin, but only for those two seconds. Everything still connected except that black wire.
        It seems like the main board not sending this voltage. I still don't understand what is causing the shutdown?
          At this point I am not sure what I can do to troubleshoot the main board.
          • tibimakai
            • Jan 2012
            • 3680
            It looks like the problem is with the mainboard, no?
            • tibimakai
              • Jan 2012
              • 3680
              I was looking for a mainboard on Ebay and I the person selling one of the boards did not specify the exact model number and I have asked about it while I have explained my problem and this is what he said:
              "If you forced the TV to turn on then your power supply should be good, you could have a bad main board or a bad IR sensor (there known to go bad and kill the data line) thus preventing the TV from turning on."
              Bottom line is still a bad mainboard, no? Or should I try getting an IR board first or could we try turning on without that board? It's possible?
                That is what I think right now that the main board is bad.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Found a main board for $42.50 on Ebay.
                  Arrived today, replaced it and it works great.
                  Just in case I have updated the firmware. Cheap nice 2010 TV. $50+ $42.50+ a bit of gas= ~$100.
                  Thank you Bud. I owe you a couple of beers if we meet somewhere.
                    That is great news, I am beginning to wonder about these Sony error codes as shown in the service manual.
                    Thanks for repair feedback, that is pretty good price for main SONY main board. I hope you will get good price selling it.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I think that I will keep this one, since it has 4x HDMI and sell my Samsung 46A550. It's a 2010 model, the Samsung is a 2008 TV.
                      Initially I have "purchased" another board for $85 and after paying for it, the seller realized that he actually doesn't even have that board. Lucky me.
                      • iglitare
                        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                        by iglitare
                        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                        Backlight seems to work, Sound (Setup menu after reset) works.
                        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                        With my small knowledge i would think at least the cables are good.
                        Can this happen because of a bad tcon board?
                        Or is it always a bad/shorted...
                        09-04-2025, 07:13 AM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • thelankanguy
                        Sony KD-55X9000F TCON Issue
                        by thelankanguy
                        The TV shows a black screen with no image.
                        TCON ribbon connectors were disconnected individually for image and there was no half image even.
                        Later both ribbons were disconnected and TCON voltages were tested.
                        12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                        There is also a short to ground in this circled inductor.
                        Is this a TCON issue or something else ?...
                        12-13-2024, 12:27 AM
                      • GoodCapDude
                        Sony XBR-75X940E intermittent 6 blinks error code
                        by GoodCapDude
                        Hi everyone. First post on Badcaps!
                        I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                        09-20-2025, 06:07 AM
                      • bbrain
                        Sony KD-55AG9 TCON?
                        by bbrain
                        I have this problem with my Sony 55' AG9.
                        It flashes 4x.
                        I have found the service manual, and seems it is the TCON.
                        Before I buy a TCON can someone check the vid?
                        Thanks in advance!...
                        09-19-2024, 10:50 AM
