HP-S5053 Plasma
  • MyHD120
    • 79
    HP-S5053 Plasma
    I have a chance to buy this TV. Seller says the horizontal line was there from day 1. Is this a bad panel or fixable? I hope the photo is good enough.
  • awyatt2
    • Feb 2012
    • 407
    • america
    Re: HP-S5053 Plasma
    looks like a lower buffer board issue. i believe this is a samsung plasma set if memory serves me.
      Re: HP-S5053 Plasma
      Careful. Lots of issues with bad panels on this model causing the same issue. Rare for buffer to fail in such a way. Possible... but rare.
      • MyHD120
        • 79
        Re: HP-S5053 Plasma
        Yes, sorry. It is a Samsung.
        • MyHD120
          • 79
          Re: HP-S5053 Plasma
          Thanks, tom66
          • tw2005
            • Oct 2011
            • 6458
            Re: HP-S5053 Plasma
            I have had that on a Samsung PS50Q7 which is identical chassis and panel to that and it was a simple reseat of the buffer connector. That was not the original fault, it was introduced whilst I was using it's buffer boards for another for fault finding.
            One of those things it may be simple fix, a buffer board or non repairable which you can't really tell until you get it and play with it.
            • ajshoe
              ajshoe
              • Dec 2012
              • 477
              • usa
              Re: HP-S5053 Plasma
              have this set - powers on, blue light in front flashes 4 times and then can push set on. nothing comes on, no sound. any body have service manual or suggestion. thanks
              • ricosavy
                • Jul 2012
                • 457
                • united states
                Re: HP-S5053 Plasma
                sounds like a y main but you need to do some testing
                • DjKrish
                  • Oct 2012
                  • 354
                  • SG
                  Re: HP-S5053 Plasma
                  I doubt its a plasma by seeing its design. Most probably a samsung lcd. I dont know, i might be wrong
                  • capkid
                    • Oct 2010
                    • 1339
                    Re: HP-S5053 Plasma
                    Yes, it's a plasma. I also agree with Tom that I would tread lightly on this one. I wouldn't think it's a buffer issue if "the horizontal line was there from day 1" and the TV appears to be at least 6 years old (I guess it depends on what the seller means by "day 1". He may have bought it used himself). There's some service info here: http://www.toms-service-manuals.com/...&Search=Submit
                    LG Plasma Mal-Discharge Correction Service
                    • ajshoe
                      ajshoe
                      • Dec 2012
                      • 477
                      • usa
                      Re: HP-S5053 Plasma with 4 blue blinks
                      started new thread
                      • capkid
                        • Oct 2010
                        • 1339
                        Originally posted by ajshoe
                        update: got the service manual. all voltages are good with all connectors plugged in. Y and X main boards are getting voltage but not 'on' (no heat from heatsinks). have green flashing led on digital board. set acts like it is on but no video, no OSD, or audio. all fuses on x and y are good. thanks
                        You should probably create your own thread.
                        • ArMaaN376
                          Samsung PS51E550 Plasma TV
                          by ArMaaN376
                          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                          Opened TV cover & observed foll
                          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                          How to confirm Y -Buffer board...
                          06-19-2024, 04:05 AM
                        • jm1234
                          Panasonic plasma TX-P42ST50 - 6 blinks
                          by jm1234
                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                          I checked that board for any obvious faults...
                          05-22-2024, 06:59 AM
                        • KYBOSH
                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                          by KYBOSH
                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                          No picture but you hear the TV static (white noise) playing loud and clear.
                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                          But it seems they didn't get too far and just left it.
                          When I first took a look I was amazed at how pristine the inside looked.
                          Its as if the TV had been in a time capsule.
                          Caps looked like they were just pulled off the self.
                          Copper coils had no sign of corrosion on...
                          02-01-2023, 11:10 PM
                        • chazh
                          LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                          by chazh
                          This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                          I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                          The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                          09-01-2025, 08:56 PM
                        • porfyriadhs
                          Samsung Plasma PS51D6900DS Bootloop
                          by porfyriadhs
                          Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                          Thanks a lot !!
                          10-19-2023, 11:31 AM
