Panasonic sc tnpa5081 rebuild
  • olda007
    • May 2013
    • 5
    • Czech Republic
    #421
    Re: Panasonic sc tnpa5081 rebuild
    Thank you for your reply tw2005.You are absolutely right.
    In AY version is placed IC564 (smd code H2 - AND gate).Output signal from IC564 is marked AA_SEL2 and via SC46(pin1) and on SD board via opto PC904 and IC901 (marked c14 - inverter) delivered to buffers.AA_SEL2 I measured only on SD board.SU board is powered by a signal AA_SEL via pin 9 SC46.
    In AW version, the circuit IC564 is missing.
    And the second difference I've found is 10 components placed right below the jumper SC50. R819,R820,R818,R919,R799,R798,D792,C797,IC792,IC793.
    There are no these components in AY version,only in AW.
    I try to desolder 10 components from AW and solder IC564.
    • olda007
      • May 2013
      • 5
      • Czech Republic
      #422
      No need to desolder R819,R820,R818,R919,R799,R798,D792,C797,IC792,IC793,because R915 on Sd board not placed from pin 7 SD42.But must be placed R720-22R near connector SC46.So changing version AW to AY is easy.Solder IC564(looks like TC7SH08FU-Toshiba,marked H2) and solder R720-22R from output IC564 to pin 1 SC46.TV works with full screen!
      • tw2005
        • Oct 2011
        • 6458
        Nice
        • 11alon11@gmail.com
          • Sep 2014
          • 15
          • canada
          #424
          this is what was replaced on the TNPA5105 jumper 50 no blinks
          R 401 & 402
          D451 & 490 & 491 & 618 & 652
          D721
          Q501 & 521 & 551
          Q401 & 402
          IC724
          Q661
          Q601 & 660
          Ic501 & 521
          Q451
          Q421 & 422
          Zener Diodes 871 and 872
          the picture is noisy and low in brightness both when I display the menu and picture from HDMI
          I was able to get a loaner SC board and the picture is perfect using the loaner. any ideas
          attached is the bad picture. (I did cut part of the picture as it did show a reflection of me)
          • tw2005
            • Oct 2011
            • 6458
            R 401 & 402
            D721
            Q501 & 521 & 551
            Q401 & 402
            IC724
            Q661
            Q601 & 660
            Ic501 & 521
            Q451
            Q421 & 422
            well, you must be close. Did you check any of the resistors around ic521? R521,522,506. 100 ohm x 2 and a 10ohm. If ic521 was shorted and Q521 shorted fair chance the 10 ohm could be dead
              • Sep 2014
              • 15
              • canada
              #426
              I did check resistors before and again today and thy are all good. what I am puzzled is why did Zener 871 and 872 go on this board. before I replaced them I did get a 6 blink code. I am at a lost at this problem. any other idea?
              • rockit711
                • Nov 2015
                • 63
                So after my last foray into trying to rebuild one of these I thought I would try one of the other dead boards I had gotten my hands on (this one had the "tradiditonal" IC773/Q661 failure). I was very careful to go over everything a few times.
                Thought I had caught everything failed, plugged it in and a bit of a whine and then 7 blinks (LED comes on OK then slowly fades away after 7 blinks).
                assumed I had blown everything again, but after a thorough testing everything seems fine except for PC461 which is ~shorted (16ohm)pins5-8 (VAD+5V - VAD).
                Swapped PC 461 out with a new one thinking that maybe I had missed it or it was on the edge last time and again whine and 7 blinks.
                PC461 is fried again..
                as far as I can tell that is it for failed parts. IC773 and 771 look good measurement wise(and I swapped these out anyway before trying again).
                Any suggestions?
                I'm a bit stumped TBH, looking at the schematics I'm struggling to come up with a reason how PC461 can fry and leave everything else intact.
                • paulstef
                  • Dec 2013
                  • 724
                  I've highlighted ones here which stuffed me up trying to test in cct.
                  D16451 B0ECKP000055 DIODE 1 ROHM , RF101L4S 400V 1A SHORT
                  D16482 B0FACP000003 DIODE 1 RFN25TM4SWSHORT
                  Q16452 B1JAEP000012 TRANSISTOR 1 GT45G128SHORT
                  D16702 B0ACCJ000048 DIODE 1 MA2J11100L 80v 100ma switching diode?
                  IC16521 C0ZBZ0001708 IC 1 M81737FP
                  IC16561 C0JBAU000088 IC 1 PAVCTH c541 buffer ic
                  IC16562 C0JBAU000088 IC 1 PAVCTH c541 buffer ic
                  IC16563 C0JBAB000916 IC 1 c14 INVERTER
                  IC16691 C0JBAC000363 IC 1 TC7SH00FU(TE85L,J
                  IC16724 C0CBADE00049 IC 1 BA178M05FP-E2
                  IC16771 C0CBADC00072 IC 1 78L05L, TA78L05F
                  IC16773 C0JBAB000715 IC 1 Toshiba TC7SH14F, marking HA, Schmitt NOT
                  PC16461 B3PBE0000054 IC 1 PS9856-2-F3-AX
                  Q16402 DG3D5020CSLW TRANSISTOR 1 DG3D5020
                  Q16403 DG3D5020CSLW TRANSISTOR 1 DG3D5020
                  Q16421 DG3D4020CSRP TRANSISTOR 1 DG3D4020
                  Q16422 DG3D4020CSRP TRANSISTOR 1 DG3D4020
                  Q16521 B1HFPFA00001 TRANSISTOR 1 CPH5524-TL-E
                  Q16551 B1HFPFA00001 TRANSISTOR 1 CPH5524-TL-E
                  Q16621 B1JADN000009 TRANSISTOR 1 GT30F125
                  Q16622 B1JADN000009 TRANSISTOR 1 GT30F125
                  Q16647 B1CBGD000001 FET 1 2SK3018T106,2n7002
                  Q16661 B1JAER000010 TRANSISTOR 1 RJP63F3A
                  Q16701 B1ADCN000007 TRANSISTOR 1 MMBTA92
                  Q16702 B1ABCF000231 TRANSISTOR 1 2PD601ART,215, 2SD0601A0L
                  Q16818 B1CBGD000001 FET 1 2SK3018T106,2n7002
                  R16452 D0GF5R6JA047 M 5.6 OHM,J, 1/3W
                  R16521 ERJ6GEYJ101V M 100 OHM,J,1/8W 1
                  R16522 ERJ6GEYJ101V M 100 OHM,J,1/8W 1
                  R16551 D0GD100JA059 M 10 OHM,J,1/4W 1
                  R16707 ERJ6GEYG392 M 3.9KOHM,J,1/8W 1
                  Just wanted to say thanks. very useful post
                  • t-echnics
                    • Oct 2017
                    • 8
                    • germany
                    #429
                    Hi folks,
                    I got a faulty TNPA5081AY.
                    D790 measuring is shorted.
                    What could be dead, too?
                    No visible defects or smells.
                    Just 10 blinks and no 15V if SC board is connected.
                    (P-board was already replaced)
                    Can anybody give me some hints?
                    What diode could be used for D790 - I do not find it in the part list of the service manual...
                    Bye,
                    Ralf
                    • tw2005
                      • Oct 2011
                      • 6458
                      Originally posted by t-echnics
                      Hi folks,
                      Bye,
                      Ralf
                      Hints, seriously you have 428 replies to read plus a host of other threads potentially on the same board, plus manuals and schematics.
                      Now although all my work is based on the 2D model boards and yours being 3D there will be some variation but most should still apply.
                      My hints are:
                      Write down the common parts noted to fail,
                      get the manual, read the schematics, identify the cct variations and check similar areas,
                      D790 is shorted because the 15V line is shorted which you already mentioned. It won't be the diode(unlikely) Most likely will be the IGBT driver IC521(ic16521). I expect IGBTs shorted, diodes, SMD transistors, SMD ICs, maybe burnt resistors to be bad. Remove the IGBTs first then recheck the diodes, watch out for 30F125 not dead short but low ohms say 2-300 ohms, that is also failure or just replace.
                      I've put enough into this board, someone else can pick up the torch.
                      report back what you find, don't take a pot shot at doing a couple of bits and power up because it will all go bang and do twice as much damage.
                      If you can find a smashed tv , that may be another way of getting it going again, salvaging boards.
                      • t-echnics
                        • Oct 2017
                        • 8
                        • germany
                        #431
                        I just figured out a bunch of shorted parts in that area of IC521 - as you described it. I think itΒ΄s too much effort getting and replacing the parts.
                        I think IΒ΄m going to watch out for a replacement board...
                        • tw2005
                          • Oct 2011
                          • 6458
                          It's a bit of work for sure. maybe someone rebuilds them in Germany, prices for a used board, absurd these days. I got a couple, postage probably insane from here.
                          • tw2005
                            • Oct 2011
                            • 6458
                            This board will work AK and AY both fitted to the 50"3D models
                            https://www.ebay.de/itm/Panasonic-50...QAAOSwi8VZSaqb
                            • t-echnics
                              • Oct 2017
                              • 8
                              • germany
                              #434
                              WhatΒ΄s the difference of these two boards?
                              • tw2005
                                • Oct 2011
                                • 6458
                                I believe a single capacitor. See if you can find it. , near the 3 large green caps
                                • t-echnics
                                  • Oct 2017
                                  • 8
                                  • germany
                                  #436
                                  Found it - at least C461 is missing in AK version.
                                  Unfortunately some days ago I missed to buy some PCBs of a broken TV including TNPA5081AY, which I should have bought - but at this time, I did not know I am going to need it...
                                  So I am going to wait, if I get another chance.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    My wife often wonders why I buy broken bits when nothing is broken. Opportunities are rare and the older they get the rarer they become. anyone who enjoys these Plasmas should grab a smashed TV or two and stock up. I'd keep an eye on those boards as they seem cheap in comparison or you may end up with no opportunity. Obviously you have other TV to watch.
                                    I have the V20, accumalated quite a stock, finally got my hands on the VT, mainboard failed under heat, got lucky picked up a smashed one, so main plus spares and snagged another cracked one, another set of spares.
                                    Personally I think the VT panel is more crisp than the V20.
                                    good luck with it
                                    • t-echnics
                                      • Oct 2017
                                      • 8
                                      • germany
                                      #438
                                      Same as mine ;-)
                                      Actually I got this TV with this failure for free - I already own two smaller Plasmas from Panasonic and really like their colors.
                                      So I can wait to get some spare parts, but it's really a shame I did not get the other smashed one...
                                      Thanks for your help!
                                      • t-echnics
                                        • Oct 2017
                                        • 8
                                        • germany
                                        #439
                                        Sorry to bother you again.
                                        Could I also use a AH board, if I replace the big caps and coils which are obviously different or are there any other differences?
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          You only have the two options I gave or will be a genius effort to reconstruct the AH to be AY because the circuitry in entirely different in that left hand congested area where the SC20 ribbon is.
                                          • tranquility
                                            Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                                            by tranquility
                                            i want to repair an Onkyo TX-NR809 receiver.
                                            symptoms:
                                            on power on, display appears and i hear one click. enue functions is given.
                                            - no hdmi output
                                            - audio output not tested, but i think it is not there
                                            - usb sticks are not recognized
                                            if i read out the chips with display+standby button + tone+
                                            both dts show only ????
                                            chip is D830K013BZKB4
                                            things i have done:
                                            - reflow of the dts chip without taking off and reballing
                                            - changed the aluminium caps without the big one with 25v because i dont...
                                            Today, 01:04 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                            11-20-2024, 08:52 PM
                                          • zen
                                            Txl47e5b , panasonic nand chip advice
                                            by zen
                                            Hi all
                                            Issue with this set is that after a few minutes of working , the remote control & on board functions stop working .
                                            Current software version is 1267-10402 , which i assume is the latest available , as i cannot get set to take an upgrade.
                                            Managed to obtain a working main board , which has same software version .
                                            Transplanted the TSOP 48 NAND chip , IC8900 ( 29F4G08ABADA ) from the working board into the faulty board , which now is working .
                                            This proved NAND chip is the problem , in the form of corrupt data....
                                            02-02-2021, 11:51 AM
                                          • sohail5307
                                            Need a2159 128gb nand bin file
                                            by sohail5307
                                            I have received SSD nand short A2159 macbook. I received new tsb4226 nand , but i think this is removed from iphone, I have nand programmer , if anyone have nand firmware please send me
                                            Two nand are using :
                                            Tsb4226(128gb)
                                            Tsb4226(128gb)
                                            09-16-2023, 09:20 PM
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
