40" LCD Rank Arena (rebadge?) has standby, V+ seem OK, but wont turn on.
  • wa11y
    • Feb 2013
    • 27
    Re: 40" LCD Rank Arena (rebadge?) has standby, V+ seem OK, but wont turn on.
    Just measured AC across the large filter cap and it 'sitting' at 25VAC, it spikes up to 30V regularly but never gets under 24-25VAC.. Is that normal?
      I've often thought the AC voltage reading across the cap doesn't mean much, I would only look at DC for now.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        #43
        Hahaha - i dont know - I was hoping Tom would make something of the result..Perhaps Budm will see this and chime in later.
        Does the DCV fluctuate say over a 10 second period.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #44
          see here https://www.badcaps.net/forum/showpo...1&postcount=13
          Depends on the result from the DC test.
            Whilst it may work well with a Fluke, as that is ac coupled, it will not work with most cheap meters as the AC measurement is dc coupled.
            • wa11y
              • Feb 2013
              • 27
              The DCV doesnt fluctuate at all, the SMPS really seems to be supplying all the needed voltages, with the resistor in im getting a solid +5, +12 and +24., but since my backlight doesnt light up is that likely to be the main cause? or the inverter board? And is there any way I can tell or test say the individual 'globes' of the backlight if I have a laptop inverter handy or similar? or has it all been done now? Time to throw it in the bin??
              Well I have an ancient fluke 8020a at my disposal but i dont think its any better at reading AC than my cheaper meter at anything other than 50/60hz...
              Its a sad thing to throw these things out its such a waste
                Have you checked BLON yet?
                • wa11y
                  • Feb 2013
                  • 27
                  I jumpered pin 1 to 2 with CON2, but now I look at the 'service manual' I linked on the first page of posts, it says there that CON2
                  1 ON/OFF Power switch
                  2 STB5V Stand by 5V
                  and that
                  CON8 (THAT ACTUALLY COMES FROM THE MAINBOARD TO THE INVERTER BOARD)
                  1 ON/OFF Inverter switch
                  2 ADJ Adjust backlight
                  Do I have to jump Pin1 & 2 on CON2 as well as send 5v down the ON/OFF of pin1 of CON8??? Im confused now.
                  edit: I just also realised I think at the beginning I wasnt clear at all, the standby light is constantly ON, and flashes OFF [for a split second] every ~33seconds, & not the other way around.... MIL didnt think it did this before so not sure if that means anything and it very well could have done it before and she never noticed or doesnt remember.
                    Pin 2 to ON/OFF inverter switch if you get good 24V.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #50
                      Hi Tom I think he may need more guidance.
                      I think you are saying "yes" he needs to jumper pin2 to pin1 on con 2 to get the board powered up and then if that is producing 24v on the 24vpins then he should then
                      add the jumper from pin2 on con2 to pin 1 on Con8. ( Does that need a 500/1kohm resistor in )
                        Yes, that's what I mean. I recommend a resistor for safety reasons... most boards are fine without... but some can be poorly designed.
                          "Just measured AC across the large filter cap and it 'sitting' at 25VAC, it spikes up to 30V regularly but never gets under 24-25VAC.. Is that normal?" Unless you are using good True R.M.S meter like Fluke 87, it should have AC less than 5~3% of the DC reading on the filter (you are basically looking at AC ripple on the filter cap, I.E. dc =100VDC, AC shoould be less than 5VAC).
                          "Whilst it may work well with a Fluke, as that is ac coupled, it will not work with most cheap meters as the AC measurement is dc coupled." That is correct, for now he can disregard the reading.
                          If the Inverter board uses PWM for Dimming, he may have to ifnd out if he has any AC signal on this DIm pin, otherwise it will do 2-second to black when he force on the Inverter.
                          • wa11y
                            • Feb 2013
                            • 27
                            Cool well we have back lights now!!
                            However (not sure if its an issue at all) but the power supply is making a constant very fast ticking/clicking/zapping noise , I measured across the big filter cap with my meter and I can see that the the zapping seems to be because of extremely fast voltage fluctuations, just like what was happening before but HEAPS faster (I can only see the fluctuations by looking at the analogue bar as there way too fast) ..
                            Is it normal behaviour or should it (for the most part) be 'quiet' when working? I have myself heard SMPS's in PC's making 'zapping' sounds when there working normally but nothing like this before. Never heard this from a LCD monitor either. Im sure I could hear this noise with the back on if I were standing in front of the TV its not very quiet this time.
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              #54
                              Does the backlight flicker at all along with the ticking?
                              Looks like we are back to the Main board to see why there is no BLON Signal
                              • wa11y
                                • Feb 2013
                                • 27
                                No the backlight itself appears to be functioning perfectly the screen looks just as it should.
                                Well tom already said.
                                Originally posted by tom66
                                4.6V instead of 5.2V could indicate bad caps.
                                & now realising that the mainboard actually supplys the ON voltage for backlight please tell me would it still be possible to be the caps on the mainboard?? I mean unless there is a bad eeprom or failure of one of the SMD IC's or something it probably would be right?
                                OK now what I maybe should have mentioned up first..
                                The mainboard has NOTHING but "XUNDA" caps on it... & I actually did decide to replace ONE of the 'big' 470uf caps because the ESR was 'suspect' (according to me reading the chart on my meter but I dont really have much idea here since this is really my first time using this meter). But im now just thinking maybe I should be replacing all the caps on the mainboard and hope for the best??? ... I can always remove them afterwards to use again if it doesnt work so no loss there at least.. I actually wrote down all my original readings which in ordinary 'wally' fashion I lost almost immediately after putting them all back in.
                                I might remove every cap again and give it another go.. Ill post my results here in a hour or so maybe someone will see something I didnt, its about the least I can do right now.
                                Just need to say also thanks so much to selldoor yes I was confused before with what to do and you completely cleared that up, and thanks so much tom and everyone else for the help and bearing with me so far I do really appreciate it. Thx 'guys'
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  #56
                                  Nice to get a bit of encouragement now and again. If you havent already ripped off all the caps - near the con 8 there are 2 switching transistors one has t1A on it - cant see the other. Maybe they are in the circuit to switch on the backlights.
                                  Here is the datasheet.
                                  • wa11y
                                    • Feb 2013
                                    • 27
                                    Both of those transistors have the same part numbers. The collector of Q4 goes directly to pin1 (on.off) on CON8... I tested between the base and collector, + base and emitter and got no reading on either of those transistors, are they really NPN transistors the numbers on them are t1a 86 (since its sideways im not sure it could really be 98, but I think it is 86)
                                    Well I did already take the majority of the caps off so at least here is what i got on my meter (making sure to zero it after each test).
                                    CA1 - 470uF 35V - 0.08R
                                    CA2 - 470uF 35V - 0.07R
                                    CA3 - 470uF 35V - 0.07R
                                    CA5 - 470uF 35V - 0.09R
                                    CA6 - 470uF 35V - 0.09R
                                    CA9 - 470uF 16V - 0.09R
                                    CA12 - 470uF 16V - 0.13R
                                    CA23 - 470uF 16V - 0.14R
                                    CA13 - 220uF 35V - 0.13R
                                    CA15 - 220uF 35V - 0.13R
                                    CA17 - 220uF 35V - 0.13R
                                    [[CA7, CA8, CA18, CA19, CA22, CA25, CA26, CA27, CA28, CA29, CA32, CA35, CA38,]]
                                    220uF 16V -- ALL 0.12 - 0.14
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #58
                                      I dont know if the esr is good or not - I dont have an esr meter so never bother with it.
                                      Perhaps detail the test you did on the switching transistors - they are fairly common so there may be others on your boards you can compare them with? or some on an old board you can borrow.
                                      • wa11y
                                        • Feb 2013
                                        • 27
                                        I had my meter in diode test mode, with the COM connected to the base, that's all I did on both tests.
                                        I have tested a brand new low ESR 470uF 35v cap and its 0.04 on the meter.
                                        • selldoor
                                          Slow Learner
                                          • Dec 2010
                                          • 7870
                                          #60
                                          Well I dont think that is correct - in diode mode you should have got some reading. - On resistance mode should read OL one way?
                                          See here
                                          http://www.allaboutcircuits.com/vol_3/chpt_4/3.html
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • Crystaleyes
                                            Samsung BN44-00259A standby question
                                            by Crystaleyes
                                            Hi all.
                                            I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                            SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                            Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                            The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                            08-11-2023, 05:15 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
