Toshiba 42SL738B White left side of screen
  • satinser
    • Oct 2012
    • 214
    left 50% of screen white with a few thin vertical coloured lines at varying distances apart. Right side of screen coloured vertical lines which when playing dvd film move in relation to movement of image on screen. No discernible images of any kind are visible the coloured lines blank out everything inclusive of menu graphics. Sound not affected. You can just about make out normal coloured screen on top mm or 2 of screen but not on the white half.
    Not sure whether its a Tcon or main av board problem. Be grateful for any help.
    Re: Toshiba 42SL738B White left side of screen
    See:
    https://www.youtube.com/watch?v=xHst6pKLtTE
    • satinser
      • Oct 2012
      • 214
      Many thanks for the link. From the way I have described the fault do you believe this to be the most likely cause of fault? The fault does appear to be very much like the sony tv highlighted in video. The only slight difference being a definite cut off point between the white and the coloured vertical lines. The white area is exactly 50% of screen.
      Many thanks again for your reply.
        Who made the LCD panel in this TV? (There will be a sticker on the metal plate on the back of the display panel.) Tab bond failures are becoming a significant cause of LCD TV failure nowadays.
        • satinser
          • Oct 2012
          • 214
          Lg according to sticker. Also the inverter has a LG part number. Although marked as a LCD tv it very thin more like an LED in that respect. When you take the back panel off the front surround becomes detached too.
          Do you know whether LG tvs are prone to Tab bond failures. Appreciate your replies
          • harp
            White screen repairs
            by harp
            To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
            Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
            On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
            05-13-2024, 03:43 AM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • ravi_1617
            HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
            by ravi_1617
            Hello to all ,
            I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
            Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
            on external VGA port image is perfect /normal , Attached image...
            07-25-2025, 12:07 AM
          • EazyBone
            Sharp LC-65Q620U White Screen
            by EazyBone
            Another TV topic!!
            I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
            The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
            Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
            08-21-2024, 12:56 PM
