Telefunken T32R915FHD - PSU VESTEL 17PW04-1 voltages to low
  • nopain77
    • 8
    Can anybody help me ?
    All Fuses OK, but Voltages to low.
    12V - real 8,3V
    24V - first 24V , falling down to approx. 18V if i connecting a multimeter.
    - the same failure after disconnecting the T-Con and Inverter Board.
    - replaced any caps on the PSU, no changes
    pictures follows
    Have a multimeter and no tv specific but electronic experience.
    by the way: im not a native english speaker , maybe i didnt understand some phrases ...
    Thank you
    Re: Telefunken T32R915FHD - PSU VESTEL 17PW04-1 voltages to low
    Is this an LED-LCD TV?
    Common issues with Vestels are bad caps (electrolytics & poly film.)
    Clear pictures of your board would be necessary.
    • jbfr_54
      • Dec 2012
      • 52
      • France
      Bonjour, il faudrait essayer de remplacer C214 (à priori le condensateur gris à côté du transformateur situé près de l'étiquette juste au dessus du radiateur). C'est un 15nF 630 volts MKP. Le schéma de l'alimentation peut être téléchargé chez Electrotanya ().
      Tenez moi au courant.
      Bonne chance.
      Jean
      • nopain77
        • 8
        thank you for the tipp , will replace 15nF 630 volts MKP capacitor C214.
          That is a poly-film cap.
          Good luck.
          • sabke
            • Apr 2015
            • 7
            • netherlands
            Did replacing capacitor C214 solve the problem of your tv?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              What is the issue with yours ?
              • sabke
                • Apr 2015
                • 7
                • netherlands
                Problem with my tv is, when power up tv backlight turns on but no picture.
                After +- 45 min I get a hanging picture, 10 min. later the tv is working normal again. I get 11.9v on the connector from psu to main board. On the T-con fuse I get 11.7v. When i disconnect the T-CON form main board, then i get 12.1v on on the connector from PSU to main board. So i was wondering if the problem is PSU or T-CON? I replaced already some capacitors on PSU but no good resold.
                Its a Medion LED tv 4 years old with a VESTEL 17PW04-1 PSU.
                Many thanks.
                Bas
                • thoma
                  • Sep 2012
                  • 268
                  Take a hairdryer and blow to the boards!
                  Any reaction?
                  regards thoma!
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Sounds like an issue with the Lcd display to me. Got an image of the whole backside of the Tv ?
                    • sabke
                      • Apr 2015
                      • 7
                      • netherlands
                      I try it already with the hairdryer but nothing is happening. Looks like a bad caps. but not sure. I will try later freezer spray.... Any other suggestion? Do you think the PSU it the problem? cheers....
                      • sabke
                        • Apr 2015
                        • 7
                        • netherlands
                        • sabke
                          • Apr 2015
                          • 7
                          • netherlands
                          Bye the way I do have sound all the time.
                            What DCV do you get at the T-CON fuse when you do not have pictures on the screen and when you do have pictures on the screen?
                            • sabke
                              • Apr 2015
                              • 7
                              • netherlands
                              Its stay the same 11.7v no difference.
                              • sabke
                                • Apr 2015
                                • 7
                                • netherlands
                                Main board have a cold solder problem. When MB was hot, tv was working fine. So problem solved after re-flowing main board.
                                Cheers,
                                Bas
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Thanks for update.
                                  • Tommes
                                    Telefunken D43F287N4CWII - Vestel 17MB110S - Recovery Firmware
                                    by Tommes
                                    Hey Folks,
                                    I'm searching for a Full Flash Recovery Software
                                    for my Telefunken D43F287N4CWII
                                    Mainboard Vestel 17MB110S
                                    Panel: VES430UNDB-2D-N12
                                    Productcode: 10119394
                                    Does anyone know, where I can get it ?
                                    Or is it possible, to extract it from a working mainboard ?
                                    The Support Telefunken/Vestel GER couldn't help me.
                                    The Vestel TR Support didn't answer my email.
                                    History:
                                    The main problem with my Telefunken D43F287N4CWII was,
                                    it just goes out after a while, sometimes after a...
                                    01-04-2022, 09:56 AM
                                  • Unimatrix
                                    (Vestel) Telefunken XF43G511 - Thermal problem
                                    by Unimatrix
                                    I came across this forum because I need some advice about my Telefunken XF43G511 TV. It is originally a Vestel device. For some time now I have had the problem that the TV gets a black screen when the electronics are heated up. The backlight is still there and the sound still works. It's just the screen itself that goes off. When I switch off the TV and it cools down, the TV works again after a while. Could you please give me some advice on what could be causing this problem? I have also attached some photos of the electronics.
                                    Kind regards
                                    Thomas...
                                    11-19-2023, 08:39 AM
                                  • classypenguin
                                    TV Telefunken (Vestel) D50U660R2CW - on the tv screen but every 3-4 seconds lines appear on the screen flickering
                                    by classypenguin
                                    Hey, I got an Telefunken 4K D50U TV in for repair. Since the problem is t-con flex related, I isolated the problem to one side (right flex of the t-con). I taped the flex a bit, but i couldnt get any further. I attached the pictures of the t-con board in zoom in perspective. I would appreciate help for this TV. Please note that I came from Germany, so it is a bit difficult with the time zones. Greeting Tobi...
                                    08-29-2024, 03:47 PM
                                  • Capacitorial
                                    Powersupply has all the voltages - Monitor still no power
                                    by Capacitorial
                                    Hello guys,
                                    I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                    I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                    On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                    The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                    The weird thing is, that the Power LED is powered over the TCON board.
                                    On The TCON...
                                    12-28-2024, 02:12 PM
                                  • Jaime Morillo
                                    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                    by Jaime Morillo
                                    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                    The TV was stuck on the logo and I couldn't access the update menu.
                                    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                    The image result was good, but the image is inverted.
                                    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                    08-18-2025, 11:38 AM
