Vizio SV470m wont power on (stuck in standby mode)
  • Nerd125
    • Feb 2013
    Hi guys, I'm having trouble with my Vizio SV470m 47 inch TV. It will no longer power on and is stuck in standby mode with the Vizio logo on the front remaining orange.
    Let me give you a little background information on how the problem started:
    The tv was working fine just a couple days ago, but got to where it wouldn't power on using the remote so i turned it on from the side of the TV thinking it was probably the batteries. The next day the TV would not turn on from the side power button anymore.
    I looked into the problem and researched it, and learned that a lot of times when the TV is stuck in standby mode and won't power on that it's usually the power supply board. I decided to order the power supply board (part #0500-0412-0780) and replace it myself. The part finally arrived and I replaced it thinking that was going to fix the problem, but it didn't.
    The forum I was reading on said in rare circumstances that if the power supply board didn't fix the problem that it had to be the main board. I decided to keep the new power supply board connected and ordered the main board (part #3647-0192-0150) for the TV. Got the main board in today and installed it, but the problem still remains. The TV will not "click" on. All it does is stay in standby mode with the orange Vizio light on.
    If anybody knows how to fix this problem I sure will appreciate it. I hate to throw out a perfectly good tv, but I am out of solutions to fix the problem .
    Thanks in advance!
  • drpj23
    • May 2012
    • 528
    Re: Vizio SV470m wont power on (stuck in standby mode)
    I would usually think the opposite for Vizio. Their main boards are generally the ones that go bad while their power supplies are usually made by delta and even this model looks like it has good components on it.
    You can try holding the power button for ~10sec and see if that cuts it on.
    Or if disconnecting LVDS does anything.
    Otherwise you probably have firmware issues on the main.
    You can check the regulators on the board and check if the backlights work.
    Use this: https://www.badcaps.net/forum/showth...ghlight=sv470m
    The general consensus for this though is main replacement.
    I guess your board has the suffix "5C"?
    • Nerd125
      • Feb 2013
      I will try out the suggestion on holding down the power button as soon as I get home. I'm not exactly sure what you mean by disconnecting the LVDS to see if it does anything. If you can help me understand that I will definitely give it a try. Also you asked about the main board having the suffix "5C", my main board has the suffix "5D". Is the "5C" board the one with firmware issues or something? Thanks for the reply by the way!
      • Nerd125
        • Feb 2013
        I just noticed that the main board that was originally in my tv ended in "5D" and the board I bought to replace the original ends in "5C". Could this be the problem with the tv still not powering on? I'm not sure what the different versions are because the serial number on it matches exactly up until the "5D" or "5C" in parenthesis.
        • drpj23
          • May 2012
          • 528
          I have no idea what the suffixes mean but I did some research, and 5C should still work even if the original was a 5D. I would try and see if you can get a part exchange.
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            If I were you I'd stop blindly replacing parts, put the original parts back in, take voltage readings, and find out what is wrong with this thing. So far you've gone about fixing this thing all wrong. If you read most of the repair threads here you'll see the trend of how we help anyone fix anything.
            1.First... search this site for this model number. You might find this problem solved already.
            2.Then post the pictures of your boards using manage attachments on the post page. You may have a simple fix that can be caught by techs by visually examining your board.
            3.Post voltage readings from the output connector of your power board.
            4.Then post voltages from regulators on the mainboard.
            Board swapping is costly and sometimes leaves you with more questions than answers.
            • keats11
              • Nov 2012
              • 88
              I have the same TV )SV470M), nothing happens when you press power. I have PS_ON, 5v and 12 V, yet no power to the inverters. Anyone managed to fix this one?
              • Dgtech
                E. Technician
                • Apr 2009
                • 1462
                • Steeler
                Check voltages to the mainboard regulators. If you post a picture of the mainboard (closeup and clear), I can identify the parts to check. You really should post pictures of the power board as well.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • duwane
                  MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                  by duwane
                  Hi All.
                  I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                  Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                  After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                  Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                  10-17-2023, 07:48 PM
                • fharris1977
                  Vizio D50u-D1 Dead Set No Standby
                  by fharris1977
                  Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                  12-28-2023, 10:25 AM
                • mferna14
                  Apple 820-01958-A logic board stuck on 5V .19amp
                  by mferna14
                  Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help...
                  02-21-2025, 03:42 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
