Another Philips 50PFP5532D 50" 1080i HD Plasma Television
Re: Another Philips 50PFP5532D 50" 1080i HD Plasma Television
ok tom i have had a fiddle with the bottom board i have tried two different boards and the ribbon cable is still getting hot, but could that be because these board are broken
what's the best way to test them. i did notice a very faint spark coming from what i think are surface mounted fuses i could be wrong (the little black rectangle things), it was the top board the first connection on the rightComment
If the ribbon cable is getting hot you either have the heat clamps removed, or the panekl driver is defective... unfortunately the last is condemning to the panel.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
the heat clamp is the big long ally thing that runs along the bottom of the boards oooohhh i see now that disperses the heat evenlyComment
Yes, you did not remove this while the panel was active right?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
But even 30 seconds can cook the delicate chips embedded on them, which are not user serviceable, except by replacing the plasma panel itself... not worth it. Just put it back together and hope you get original symptoms.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
ok i have put it all back together turned it on half the screen is black with faint pixels showing through, you can see the faint outlines of light on the dark-side
the sticker on the screen, its a reflection of the metal back panel
if i disconnect the ribbon cables individually the part of the black bit disappears and a whites screen takes its place. i am wondering if i have shorted the bottom boardsLast edited by joehezzer; 02-08-2013, 03:59 PM.Comment
I think the drivers have burnt out unfortunately as before you were at least getting a dodgy picture, try reseating the connectors but I am not holding out much hope.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The bottom boards don't really "short", as there's barely anything on them.
If you replaced those bottom boards perhaps swap out for the older ones that might still be good?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
There are lots of resistors on them -- basically the only thing that can fail, so test them.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yes.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
They should be something like 0.47 ohms to 10 ohms...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by celiabrownHello guys,
My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
Can someone has any symptom like this ?
Thanks05-09-2024, 10:56 PM -
by Cdm1212Hi,
I am attempting to repair my television. When I turn it on, it seems to start normally and then the backlight turns off after a couple seconds.
Initially on the main power board I replaced diode D1202 which was shorted, and capacitor C1201 which was bulging. I was still getting some wonky voltages, so also replaced C1204, C1250 on the main board, as well as the filter caps on the LCD module, which were 3 680uf caps in parallel, which I replaced with 2 1000uf caps in parallel.
The tv is still showing the same symptoms, although now... -
by renechhello,
I hope someone on this forum can assist me.
I have a panasonic TH-42PC77U plasma television.
the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
I have read some posts that suggest the problem is related to the boards on the left... -
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by janos6662000Hi
I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
When i applied cable signal to check image, i had normal picture, but TV was restarting.
I downloaded original firmware and applied the update, but the problem remained.
From a colleague i received a "factory package software" which is a lot bigger.
I made another firmware update, but still did not solve the problem.
Somewhere on the way the error got worse, because at the moment the... - Loading...
