Another Philips 50PFP5532D 50" 1080i HD Plasma Television
  • joehezzer
    • Jul 2012
    • 251
    • England
    hi guys ok so i have a Philips 50PFP5532D 50" . i have replaced two caps on the power supply
    before i replaced two bottom buffer boards and the sustain board. the tv powers up but half the screen was black. since i replaced the board the tv now just stays on but no screen.
    i will try and post video
  • joehezzer
    • Jul 2012
    • 251
    • England
    Re: Another Philips 50PFP5532D 50" 1080i HD Plasma Television
    this should be the vid
    http://www.youtube.com/watch?v=hEOUl...ature=youtu.be
    when you see the power light go out on the front of the set it is bacause i have just turned the power switch off
    • joehezzer
      • Jul 2012
      • 251
      • England
      ok so all the boards and caps that are marked red have been replaced
        The lower boards are not buffer boards. Really they are just fancy connectors. Not much on them to fail. You need to replace the Y-buffers, if you were told to replace some buffer boards.
        • joehezzer
          • Jul 2012
          • 251
          • England
          i see i am still learning lol
          i replaced the one board to the right as i noticed one of the big heatsink was getting very hot, so i replaced the board
            HOT is GOOD. Cold is not.
              Try running it with the Y-main disconncted. You will not see a picture. Check Vs and Va are present and good. Count the blinks on that PSU LED.
              • joehezzer
                • Jul 2012
                • 251
                • England
                ok so i just tested vs output
                they all measured 1.4 volts and the led just keeps blinking green on the psu
                  Vs is 1.4V with or without connectors plugged in?
                  • joehezzer
                    • Jul 2012
                    • 251
                    • England
                    that's without connectors plugged in.
                    ok just had another fiddle disconnected the bottom boards, and the psu kicked itself on.
                    • joehezzer
                      • Jul 2012
                      • 251
                      • England
                      i changed the one of the long bottom boards over half the screen works. i started to check the connections on the bottom board and noticed a few of the were very hot
                      so i disconnected them and got the screen to do this
                      • joehezzer
                        • Jul 2012
                        • 251
                        • England
                        is there any easy way to test these boards.
                        and thanks for your help so far tom
                          You either have a bad plasma panel, rare, or loose connectors on that bottom board.
                          Black bars are bad panel or board. But they're usually only 2"~3" thick if a bad panel.
                          DO NOT MAKE CHANGES TO THESE CONNECTORS WITH POWER PLUGGED IN!!! I CANNOT EMPHASISE THIS FURTHER!!! YOU WILL KILL THE PANEL.
                          • joehezzer
                            • Jul 2012
                            • 251
                            • England
                            thanks tom, i did replace the bottom boards with new ones it worked for a while, but noticed that the screen started to get the thick black lines down it, but what i did not do was replace this board
                            so i think i may have shorted the new bottom boards
                              No, you just need to re-seat the connectors on that board. The X-main in your photo is not at fault.
                              • joehezzer
                                • Jul 2012
                                • 251
                                • England
                                so you think i could be a bad connection on the bottom boards then
                                  Yes.
                                  And heed my warning above.
                                  • joehezzer
                                    • Jul 2012
                                    • 251
                                    • England
                                    Yes.
                                    yes most defo will heed your warning. will have a mess tomoz and will let you know how it goes, atleast the power supply seems to be good
                                    • Mark369
                                      • Jul 2009
                                      • 163
                                      Re: Another Philips 50pfp5532D 50" 1080i HD Plasma Television
                                      this is the same photo as this post
                                        Also, make sure to always have the heatsinks on those boards installed when powering up.
                                        • celiabrown
                                          Issue with Plasma Philips 37inch chassis FTL2.1
                                          by celiabrown
                                          Hello guys,
                                          My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                          Can someone has any symptom like this ?
                                          Thanks​
                                          05-09-2024, 10:56 PM
                                        • Cdm1212
                                          Philips model 46pfl3706/f7 television
                                          by Cdm1212
                                          I am attempting to repair my television. When I turn it on, it seems to start normally and then the backlight turns off after a couple seconds.
                                          Initially on the main power board I replaced diode D1202 which was shorted, and capacitor C1201 which was bulging. I was still getting some wonky voltages, so also replaced C1204, C1250 on the main board, as well as the filter caps on the LCD module, which were 3 680uf caps in parallel, which I replaced with 2 1000uf caps in parallel.
                                          The tv is still showing the same symptoms, although now...
                                          02-22-2024, 07:33 PM
                                        • renech
                                          panasonic TH-42PC77U plasma television half screen problem
                                          by renech
                                          hello,
                                          I hope someone on this forum can assist me.
                                          I have a panasonic TH-42PC77U plasma television.
                                          the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                          i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                          I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                          I have read some posts that suggest the problem is related to the boards on the left...
                                          12-12-2022, 06:53 PM
                                        • Sharpa
                                          Repair attempt Philips 55OLED804/12
                                          by Sharpa
                                          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                          The symptoms when bought: Philips logo appears then tv turns off
                                          Things tried so far:
                                          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                          Today, 08:30 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
