Another Philips 50PFP5532D 50" 1080i HD Plasma Television
    Re: Another Philips 50PFP5532D 50" 1080i HD Plasma Television
    Try 200 ohm range (no "k").
    • joehezzer
      • Jul 2012
      • 251
      • England
      #42
      ok, so i tried that and i get a quick flash of digits then i just sits on what i think is infinite resistance (1.) the reading i get is the same as i get when both connections on the multi meter are not touching each other. does that make sense
        Can you show me where you are probing?
        • joehezzer
          • Jul 2012
          • 251
          • England
          #44
          Yep
          • joehezzer
            • Jul 2012
            • 251
            • England
            #45
              Those are the correct resistors. They should measure 4.7 ohm. But if they are all failed I would suspect the plasma panel drivers.
              • joehezzer
                • Jul 2012
                • 251
                • England
                #47
                I wonderd because this board had gone down
                [/QUOTE]
                That it may have shorted the longer bottom board. I suppose i am just defo ruling out every other possible out come. And the panel is defo broke
                  The X-main (large right board) can't cause that.
                  • joehezzer
                    • Jul 2012
                    • 251
                    • England
                    #49
                    Ok. some of the resistors i seem to be getting 16.5 ohs and some i am not getting any readings at all
                      1.65 ohm (may read 1.6 or similar) might be reasonable.
                      • joehezzer
                        • Jul 2012
                        • 251
                        • England
                        #51
                        because the panel drivers are broke would that cause the break down of the long bottom panel ?
                        Looks like i will be stripping it for parts lol
                          Yes quite possibly.
                          • joehezzer
                            • Jul 2012
                            • 251
                            • England
                            #53
                            I do appreciate your help dude . At least i know the power supply workslol
                              And the Y-main, Y-buffers, video board, control board and X-main.
                              • celiabrown
                                Issue with Plasma Philips 37inch chassis FTL2.1
                                by celiabrown
                                Hello guys,
                                My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                Can someone has any symptom like this ?
                                Thanks​
                                05-09-2024, 10:56 PM
                              • Cdm1212
                                Philips model 46pfl3706/f7 television
                                by Cdm1212
                                I am attempting to repair my television. When I turn it on, it seems to start normally and then the backlight turns off after a couple seconds.
                                Initially on the main power board I replaced diode D1202 which was shorted, and capacitor C1201 which was bulging. I was still getting some wonky voltages, so also replaced C1204, C1250 on the main board, as well as the filter caps on the LCD module, which were 3 680uf caps in parallel, which I replaced with 2 1000uf caps in parallel.
                                The tv is still showing the same symptoms, although now...
                                02-22-2024, 07:33 PM
                              • renech
                                panasonic TH-42PC77U plasma television half screen problem
                                by renech
                                hello,
                                I hope someone on this forum can assist me.
                                I have a panasonic TH-42PC77U plasma television.
                                the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                I have read some posts that suggest the problem is related to the boards on the left...
                                12-12-2022, 06:53 PM
                              • alro7779
                                Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                by alro7779
                                Hello, guys!
                                The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                09-14-2025, 12:25 AM
                              • G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                by G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                It does power up when pressing the power button.
                                I already try the power button while plugin the plug with no result.
                                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                Could this be an PSU or eMMC issue ?
                                07-19-2025, 03:43 AM
