Another Philips 50PFP5532D 50" 1080i HD Plasma Television
  • joehezzer
    • Jul 2012
    • 251
    • England
    Re: Another Philips 50pfp5532D 50" 1080i HD Plasma Television
    Originally posted by Mark369
    this is the same photo as this post
    yes
    • joehezzer
      • Jul 2012
      • 251
      • England
      Re: Another Philips 50PFP5532D 50" 1080i HD Plasma Television
      ok tom i have had a fiddle with the bottom board i have tried two different boards and the ribbon cable is still getting hot, but could that be because these board are broken
      what's the best way to test them. i did notice a very faint spark coming from what i think are surface mounted fuses i could be wrong (the little black rectangle things), it was the top board the first connection on the right
        If the ribbon cable is getting hot you either have the heat clamps removed, or the panekl driver is defective... unfortunately the last is condemning to the panel.
        • joehezzer
          • Jul 2012
          • 251
          • England
          the heat clamp is the big long ally thing that runs along the bottom of the boards oooohhh i see now that disperses the heat evenly
            Yes, you did not remove this while the panel was active right?
            • joehezzer
              • Jul 2012
              • 251
              • England
              #26
              i removed it once panel was turned off, then tried it, but literately for seconds as it got hot ooooppppss
              • joehezzer
                • Jul 2012
                • 251
                • England
                #27
                none of the ribbon cables look burnt or damaged and all contacts look good
                  But even 30 seconds can cook the delicate chips embedded on them, which are not user serviceable, except by replacing the plasma panel itself... not worth it. Just put it back together and hope you get original symptoms.
                  • joehezzer
                    • Jul 2012
                    • 251
                    • England
                    #29
                    ok i have put it all back together turned it on half the screen is black with faint pixels showing through, you can see the faint outlines of light on the dark-side
                    the sticker on the screen, its a reflection of the metal back panel
                    if i disconnect the ribbon cables individually the part of the black bit disappears and a whites screen takes its place. i am wondering if i have shorted the bottom boards
                      I think the drivers have burnt out unfortunately as before you were at least getting a dodgy picture, try reseating the connectors but I am not holding out much hope.
                      • joehezzer
                        • Jul 2012
                        • 251
                        • England
                        #31
                        i am wondering if i have shorted the bottom boards as i am still getting lot of pixels
                          The bottom boards don't really "short", as there's barely anything on them.
                          If you replaced those bottom boards perhaps swap out for the older ones that might still be good?
                          • joehezzer
                            • Jul 2012
                            • 251
                            • England
                            #33
                            is there a way i can test the board, because if the panel if broke i would like to know if boards still work
                            i did try the old boards and the set would not turn on
                              There are lots of resistors on them -- basically the only thing that can fail, so test them.
                              • joehezzer
                                • Jul 2012
                                • 251
                                • England
                                #35
                                So all the little black rectangle things are resistors
                                  Yes.
                                  • joehezzer
                                    • Jul 2012
                                    • 251
                                    • England
                                    #37
                                    Yes.
                                    ok cool i will have alook tomorrow, thanks tom you have been a great help
                                    • joehezzer
                                      • Jul 2012
                                      • 251
                                      • England
                                      #38
                                      not sure if i am doing it right but i have measured resistors and i am getting 0.03 ohms
                                        They should be something like 0.47 ohms to 10 ohms...
                                        • joehezzer
                                          • Jul 2012
                                          • 251
                                          • England
                                          #40
                                          i have my multi meter set on 200k ohm not sure if i have set it right
                                          • celiabrown
                                            Issue with Plasma Philips 37inch chassis FTL2.1
                                            by celiabrown
                                            Hello guys,
                                            My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                            Can someone has any symptom like this ?
                                            Thanks​
                                            05-09-2024, 10:56 PM
                                          • Cdm1212
                                            Philips model 46pfl3706/f7 television
                                            by Cdm1212
                                            I am attempting to repair my television. When I turn it on, it seems to start normally and then the backlight turns off after a couple seconds.
                                            Initially on the main power board I replaced diode D1202 which was shorted, and capacitor C1201 which was bulging. I was still getting some wonky voltages, so also replaced C1204, C1250 on the main board, as well as the filter caps on the LCD module, which were 3 680uf caps in parallel, which I replaced with 2 1000uf caps in parallel.
                                            The tv is still showing the same symptoms, although now...
                                            02-22-2024, 07:33 PM
                                          • renech
                                            panasonic TH-42PC77U plasma television half screen problem
                                            by renech
                                            hello,
                                            I hope someone on this forum can assist me.
                                            I have a panasonic TH-42PC77U plasma television.
                                            the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                            i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                            I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                            I have read some posts that suggest the problem is related to the boards on the left...
                                            12-12-2022, 06:53 PM
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
