looking for panasonic upper buffer
  • awyatt2
    • Feb 2012
    • 407
    • america
    hello all, find myself in need of an upper buffer that no one seems to have. tnpa4188 su of upper buffer board. it fits a th50px75u. heck of a nice tv if i can find the buffer. bottom half has a perfect pic upper half is black with startup glow. must be an open igbt the resistors, caps, diodes check good does not seen to have a fuse on it. anyone happen to have one in the spares box?
    Re: looking for panasonic upper buffer
    Startup glow on top half could actually indicate a bad D board...
    • awyatt2
      • Feb 2012
      • 407
      • america
      tom, any ideas on how to determine without buying both boards? my luck runs bad and whichever one i get i will end up needing the other.
      did you get the disc yet been about a week. don't know if it will get caught in customs or not.
      i have a 150 meg tektronix scope, never used it much though mostly monitoring ripple in dc power supplys that i build. any input on this panasonic will be appricated greatly. i have a startup glow but no pic can see three distinct black lines in the top part bottom is perfect. i forgot and left the little plastic connector off and started it up and got three colored sections at the top and black lines were gone. these were blocks equally spaced across in a horiz. pattern and went halfway down. the upper buffer chips dont get warm at all the lower ones get warm but not to the point they would burn. that was what the assumption of sd board.
        No sign of disc unfortunately. I'm keeping an eye out for it.
        The buffer boards just select the appropriate line to write to; you should see more or less the same waveform on each buffer output, same as Y-sus. You could probe the last output on each connector and see if you see a good Y-sus waveform.
        • awyatt2
          • Feb 2012
          • 407
          • america
          good call Tom, saved me from looking for what i dont need it seems that it might be the d board, so now i am in search of a logic controller.
            Can't guarantee it's the D board though, do the check I suggested.
            • awyatt2
              • Feb 2012
              • 407
              • america
              i did tom, the signal on the top is out, but approx the same as in.bottom looks good both sides. top is not getting the signal in to go out. hope this makes sense to you no other way i know to explain it.
                Sort of -- so you think D board?
                • awyatt2
                  • Feb 2012
                  • 407
                  • america
                  i am gonna try it, hopefully it will get her running. nice tv i fixed an older panasonic a couple of weeks back for my daughter. this one is a friends set. he has a 62 i think he said that is working when it wants to if i can fix this one i can have the other one, which he is watching now.i cant remember if it was 62 or 65, it is a huge set though.
                  • awyatt2
                    • Feb 2012
                    • 407
                    • america
                    found a problem on the sc or ysus, two fets in series one has voltage in and out one has in no out. am going to the service manual now to see if i can find the sc board schematic.
                      http://www.tgohome.com/ServiceManual...&Search=Submit
                      • awyatt2
                        • Feb 2012
                        • 407
                        • america
                        looking like it may be the sc board i tried the d board and no improvment, the upper buffer was putting out basically what it was sent. some of these are a pain i guess. now i pull the sc and start trying to find the dead bird in the flock.
                          I doubt it's the SC. The SC sends the same signals to both boards. Any different signals are routed through the SC to SU/SD from D board.
                          • awyatt2
                            • Feb 2012
                            • 407
                            • america
                            upper buffer board, nothing else left. i figured it would be the last place i went. anyway i am still trying to source one. no luck not even ebay.tpna 4188.tried the d board and the sc board to no avail and both are known working boards.
                            • tw2005
                              • Oct 2011
                              • 6458
                              Maybe your filter is not set to worldwide?
                              All these in UK, this one is cheapest and maybe worth buying 2 or just in case you get sent a bad one. Cheap post as well.
                              http://www.ebay.com/itm/TNPA4188-1-S...item460c406ed7
                              Has 3, ships worldwide
                              http://www.ebay.com/itm/New-Panasoni...item20c9054327
                              http://www.ebay.com/itm/PANASONIC-TH...item460aceacb0
                              • awyatt2
                                • Feb 2012
                                • 407
                                • america
                                tw2005, most of the australia places wont ship to the us because of customs and paperwork. every place i have tried here is out. the local ones on ebay are far overpriced. so i will button it up and play the waiting game.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  All those were UK not Aust and ship worldwide as quoted in ebay. First link was the cheapest.
                                  • awyatt2
                                    • Feb 2012
                                    • 407
                                    • america
                                    check the shipper info, when you try to get a quote they will tell you no shipping to usa.i know because i tried the reply was due to customs and holding times there was no shipping to us. guess they think tv parts are security risks.
                                    i finally found one, replaced the upper buffer and bam! the tv came on full screen. just finished the job and picture is beautiful. may be replacing the samsung as i like the non glare screen. side tracked because of the avability of the buffer boards for this tv guess they are high failure.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Most frustrating, I have the same issues at time finding stock but no ship to AU. Any excuse I guess, anyway you got one so well done.
                                      At least SJ has ship in order, very professional.
                                      • howardc64
                                        by howardc64
                                        Problem
                                        08-04-2024, 10:36 PM
                                      • Andre Gilbert
                                        by Andre Gilbert
                                        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                        11-20-2024, 08:52 PM
                                      • Yanleb
                                        Schematic or datasheet for Plasma TV buffer chip
                                        by Yanleb
                                        I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                                        So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                                        Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                                        05-18-2022, 01:36 PM
                                      • AquaMan Ua
                                        by AquaMan Ua
                                        05-17-2025, 09:40 AM
                                      • skyvalley99
                                        Panasonic 50VT65 Sparkling/misfiring pixels upper half of screen
                                        by skyvalley99
                                        Recently my VT65 has started exhibiting sparking/misfiring pixels, it manifests as sparkling white pixels in the black area if there's brighter pixels in the same horizontal area (e.g. the smart viera boot screen, white credits on a black background).
                                        On inspecting the screen closley you can see pixels misfiring in the upper area of the screen at all time, it just gets lost in normal content.
                                        I've tried (without success) replacing the P/SS/SC board (refurbished boards) and re-calibrating the VSUS (including setting it to HIGH) but none has made a difference.
                                        02-21-2021, 01:24 PM
