hello all, find myself in need of an upper buffer that no one seems to have. tnpa4188 su of upper buffer board. it fits a th50px75u. heck of a nice tv if i can find the buffer. bottom half has a perfect pic upper half is black with startup glow. must be an open igbt the resistors, caps, diodes check good does not seen to have a fuse on it. anyone happen to have one in the spares box?
looking for panasonic upper buffer
Re: looking for panasonic upper buffer
tom, any ideas on how to determine without buying both boards? my luck runs bad and whichever one i get i will end up needing the other.
did you get the disc yet been about a week. don't know if it will get caught in customs or not.
i have a 150 meg tektronix scope, never used it much though mostly monitoring ripple in dc power supplys that i build. any input on this panasonic will be appricated greatly. i have a startup glow but no pic can see three distinct black lines in the top part bottom is perfect. i forgot and left the little plastic connector off and started it up and got three colored sections at the top and black lines were gone. these were blocks equally spaced across in a horiz. pattern and went halfway down. the upper buffer chips dont get warm at all the lower ones get warm but not to the point they would burn. that was what the assumption of sd board.
Originally posted by awyatt2 View Posttom, any ideas on how to determine without buying both boards? my luck runs bad and whichever one i get i will end up needing the other.
Originally posted by awyatt2 View Posti have a 150 meg tektronix scope, never used it much though mostly monitoring ripple in dc power supplys that i build. any input on this panasonic will be appricated greatly. i have a startup glow but no pic can see three distinct black lines in the top part bottom is perfect. i forgot and left the little plastic connector off and started it up and got three colored sections at the top and black lines were gone. these were blocks equally spaced across in a horiz. pattern and went halfway down. the upper buffer chips dont get warm at all the lower ones get warm but not to the point they would burn. that was what the assumption of sd board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Can't guarantee it's the D board though, do the check I suggested.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
i am gonna try it, hopefully it will get her running. nice tv i fixed an older panasonic a couple of weeks back for my daughter. this one is a friends set. he has a 62 i think he said that is working when it wants to if i can fix this one i can have the other one, which he is watching now.i cant remember if it was 62 or 65, it is a huge set though.
I doubt it's the SC. The SC sends the same signals to both boards. Any different signals are routed through the SC to SU/SD from D board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Maybe your filter is not set to worldwide?
All these in UK, this one is cheapest and maybe worth buying 2 or just in case you get sent a bad one. Cheap post as well.
http://www.ebay.com/itm/TNPA4188-1-S...item460c406ed7
Has 3, ships worldwide
http://www.ebay.com/itm/New-Panasoni...item20c9054327
http://www.ebay.com/itm/PANASONIC-TH...item460aceacb0
Originally posted by awyatt2 View Posttw2005, most of the australia places wont ship to the us because of customs and paperwork. every place i have tried here is out. the local ones on ebay are far overpriced. so i will button it up and play the waiting game.
check the shipper info, when you try to get a quote they will tell you no shipping to usa.i know because i tried the reply was due to customs and holding times there was no shipping to us. guess they think tv parts are security risks.
i finally found one, replaced the upper buffer and bam! the tv came on full screen. just finished the job and picture is beautiful. may be replacing the samsung as i like the non glare screen. side tracked because of the avability of the buffer boards for this tv guess they are high failure.
