Technika LCD42-910 Stuck in standby
    Re: Technika LCD42-910 Stuck in standby
    IO board is what I was after. How hard would it be for you to check each pin?
    • KevT
      • Feb 2013
      • 17
      • England
      I guess knowing the process would be the main issue. Would you want me to check the voltages across each pair? My electronics knowledge is sketchy to say the least.
        Your meter should be set on DC200V.
        Measure each pin... try to follow any board numbering if that's not available then just be consistent in whatever pattern you use.
        Note & post the reading here.
        • KevT
          • Feb 2013
          • 17
          • England
          Taking the schematic I posed before (), do you mean checking the voltages across, say, pins 1 and 2 and repeat for each pair?
          Would I remove all other connectors for this, or do they have to remain in place?
            Test 1 relative to case.
            Test 2 relative to case.
            etc.etc.
            • KevT
              • Feb 2013
              • 17
              • England
              #26
              Well, here goes. I measured from the back of the pin.
              With all boards disconnected:
              1 - 0
              2 - 0
              3 - 0.8
              4 - 0.8
              5 - 0
              6 - 0
              7 - -0.1
              8 - 0
              9 - 0
              10 - 14.3
              11 - 14.3
              12 - 14.3
              13 - 4.2
              14 - 4.2
              15 - 4.2
              16 - 4.2
              17 - 3.3 (5.0 sometimes!)
              18 - 3.3 (5.0 sometimes)
              19 - 3.3 (5.0 sometimes)
              20 - 3.3
              21 - 3.3
              22 - 3.3
              23 - 0
              24 - 0
              25 - 29.0
              26 - 29.0
              27 - 0
              28 - 0
              With all boards connected:
              1 - 0
              2 - 0
              3 - 0.8
              4 - 0.8
              5 - 2.0
              6 - 2.0
              7 - 0.5
              8 - 0.5
              9 - 0
              10 - 0
              11 - 0
              12 - 0
              13 - 4.2
              14 - 4.2
              15 - 4.2
              16 - 4.2
              17 - 0.5
              18 - 0.5
              19 - 0.5
              20 - 0.5
              21 - 0.5
              22 - 0.5
              23 - 0
              24 - 0
              25 - 0 (seemed to peak at 29.0 and drop to 0)
              26 - 0 (seemed to peak at 29.0 and drop to 0)
              27 - 0
              28 - 0
              I had quite some variations in these measurements, but those are the most consistent I got. Changes to the values happened when I switched the TV on using it's on set button, and after about 30 seconds following a high pitched whining noise. Hmm.
                I'm thinking main board issue. Just checking, did you use volts DC?
                • KevT
                  • Feb 2013
                  • 17
                  • England
                  #28
                  Yes (solid line, dotted line), and I made sure I was testing right by googling the process, so I'm fairly happy with what I got. Couldn't quite get why pins 25 and 26 dropped dramatically after about 30s though. Not much like the numbers on the schematic.
                    29V on 24V tells me that your meter battery is probably low or dead... it needs replacement. As a multimeter battery runs flat, readings begin to rise.
                    • KevT
                      • Feb 2013
                      • 17
                      • England
                      #30
                      Right, I'll do that then. Maybe check the voltages again after.
                      So it looks more like the main board rather then the power supply?
                        Since PSU is producing what looks to be OK voltages, yes, it looks to be more main board than PSU right now.
                        • exmortis
                          • Feb 2013
                          • 27
                          • u.k
                          #32
                          Hi Did you resolve this as i have same issue with a T.v , the tv powers on and the screen lights up then powers down again, and the psu buzz's any ideas.
                          • KevT
                            • Feb 2013
                            • 17
                            • England
                            #33
                            No, afraid not yet. Getting parts is not easy. I may well have put poor caps on the psu. Did that before I came on here
                            • exmortis
                              • Feb 2013
                              • 27
                              • u.k
                              #34
                              i changed some caps on the psu, now the fault has changed the LCD is complete stuck in standby clicks on then off with a couple of secs and the psu still buzzing from the relay unit which clicks over nightmare .
                              • grime
                                • Jun 2014
                                • uk
                                #35
                                hi any idea coz i have the same problem
                                • grime
                                  • Jun 2014
                                  • uk
                                  #36
                                  i have multimiter and i have knowledg on electronic part can any one help me to sort out this problem pls
                                  • matyka
                                    • Jan 2015
                                    • 179
                                    • Uk
                                    #37
                                    Hi,have the same problem here,any help would be much appreciated.
                                    • matyka
                                      • Jan 2015
                                      • 179
                                      • Uk
                                      #38
                                      hi,have the same problem on my board.
                                      replaced the capacitors and I got the same buzzing sound.
                                      have you found out what is the problem ?
                                      • matyka
                                        • Jan 2015
                                        • 179
                                        • Uk
                                        #39
                                        hello,after I took the logic board off and try to power on ,but after a few seconds shut off on goes in standby mode again .
                                        I managed to take some measurement on PL816 and all are good just one the number 13 should be +33v and I have no reading .
                                        Someone would tell me the next step would be please ???
                                        • lepak06
                                          TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                          by lepak06
                                          Hello
                                          I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                          The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                          Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                          All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                          But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                          01-12-2023, 01:43 AM
                                        • lego1234567
                                          LG 32LB1R - stuck in standby mode
                                          by lego1234567
                                          Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                          What could be the problem ? Thanks...
                                          01-21-2024, 03:39 AM
                                        • Stunt
                                          Hp Laptop Stuck on Hp protected by hp sure start screen
                                          by Stunt
                                          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                          screen that's it and stuck there. I left it until the following day and i still...
                                          09-02-2025, 01:51 PM
                                        • Rusenga
                                          Samsung UA39EH5003R Stuck on standby
                                          by Rusenga
                                          Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                          Connector CNM803:
                                          TV ON
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                          TV OFF
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                          09-18-2021, 11:51 AM
                                        • Ukdigger
                                          Samsung UE46f5000AK Stuck on Standby
                                          by Ukdigger
                                          When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
                                          PSU number bn44-00610A L46SF_dpn
                                          1 B13v 12.4
                                          3 B13v 12.4
                                          5 Vamp 12.4
                                          7 Vamp 12.4
                                          9 GND...
                                          08-08-2024, 09:17 AM
