Bad transformer
    Re: Bad transformer
    I found a transformer and soldered it to the board.Tv works great now.That little trans former had a pri.,sec.,and a aux.I changed F1 to a fast blow just for piece of mind,and i soldered a fuse holder on bottom of board .The fuse that was on the board was hard wired on,and it had no value on it. Think it acted like a jumper and killed mt trans coils. Thanks again every one.
      Re: Bad transformer
      You... found... a transformer? Just any old transformer? Put it in and it worked?
      That is like saying, my Ford's car engine is broken, but I found an engine from a Toyota, and it worked.
        Re: Bad transformer
        Especially that, the so called transformer that he asked is not transformer but inductor and is part of the PFC Voltage booster circuits, he better check his DC voltage on the main cap to see what he is getting.
          Re: Bad transformer
          where did you found you inductor , i have the same problem as you , and can you tell me
          what's the part number on the 16pin IC , mine is scratch out from factory
          thank's
            Re: Bad transformer
            Good day guys,
            I am looking for a schematic/ service manual for a Proscan 32LA30Q. I especially need the schematic for the PSU. Board number SBGD-200-3HP.
            Any help in this regard will be highly appreciated.
            Regards
              Re: Bad transformer
              if the data sheets match on both transformers, shouldn't be any problems, NICE FIX.
                Re: Bad transformer
                Wonder if you actually read the thread? It was NOT a TRANSFORMER
                it was an inductor.
                It is an old thread was only kicked as pretorif is looking for a schematic
                Anyone else reading this see above - pretorif looking for a schematic.
                  Re: Bad transformer
                  I READ THIS, what did you read????
                    Re: Bad transformer
                    it was an inductor.
                    YEP read the whole thread.
                      Re: Bad transformer
                      and I don't care how old the thread is, my friend fixed his tv, and I said NICE FIX.
                        Re: Bad transformer
                        ok
                        Originally posted by pretorlf View Post
                        Good day guys,
                        Regards
                          Re: Bad transformer
                          Ok
                          i found a transformer and soldered it to the board.tv works great now.that little trans former had a pri.,sec.,and a aux.i changed f1 to a fast blow just for piece of mind,and i soldered a fuse holder on bottom of board .the fuse that was on the board was hard wired on,and it had no value on it. Think it acted like a jumper and killed mt trans coils. Thanks again every one.
                          ok
                            Re: Proscan 32LA30Q.
                            Please can anyone help this guy out
                            Good day guys,
                            Regards
