I have a Vizio vp 422 that will not power on. I did find a thread for this same tv, but there was no final solution. I'm a newbie so I'm open to all suggestions. All caps appear to be good. I've checked voltages on all coonectors from power supply. The PS-ON voltages are 4.07 in standby, and .48 with power on. Fuses all check out, including f-1,2,3,4. The PN for the main board is 0171-2272-2587. I'm wondering if the small board sandwiched between the main board & the back of screen could be the issue? I think it's called the control board. Please forvive my ignorance.
Vizio vp422- will not power on
Tags: None -
Re: Vizio vp422- will not power on
Update: I now hav sound, but no picture. I cannot change channels with the remote or by pushing buttons on tv. The only things that work are the volume & the input, but I lose the sound when I push input. I can switch to one additional channel by pushing last on the remote. -
If you can get into the menues perhaps a factory reset would sort it out.
See the "sticky" on this forum
By the way - double posting is frowned upon as it wastes our time.Last edited by selldoor; 01-28-2013, 12:14 PM.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
