Vizio SV422XVT no backlight, photos and details inside
    Re: Vizio SV422XVT no backlight, photos and details inside
    Sorry about the designator mixed up. If that fusible resistor is open (check it with the TV unpluged and the the two large caps are discharged), then you need to take the resistance reading of all 8 MOSFET to see if they are shorted out. Looking at the MPSFET with tab on top, call the left pin as pin one, big tab is pin 2, right pin as pin 3. Take the reading and report them like this:
    1-2 = xxx Ohms
    1-3 = xxx Ohms
    2-3 = xxx Ohms
    FBxxx is piece of wire fed through a small Ferrite bead (it is basically a very small inductor), it will show as 0 Ohm.
    • gustagen
      • May 2011
      • 86
      I'll report back with the transistors' resistance measurements as well as confirmation of the fusible resistor's condition.
      What's the best way to discharge the large caps? In the past I've shorted small caps with an insulated screwdriver. I don't have many spare parts available, so I don't have a resistor to discharge them through. Would a household 120V lightbulb or 12V automotive bulb work?
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        We usually suggest a 10k 2 w resistor ( or Higher), If you dont have one most modern caps do self discharge within a few minutes but given that this is on a faulty board I would set my meter on 600vdc and just test the caps after it has been off for a few minutes- puts it beyond doubt.
        • gustagen
          • May 2011
          • 86
          Before testing, I measured the voltage across both C909 and C910. Both had discharged since my last session of testing.
          I then measured for resistance across the points contained within the box marked "GR3." I am using an auto-ranging multimeter, and it read "0 L," which seems to indicate "infinite resistance" according to my Googling.
          I also measured the resistances of eight MOSFETs on the rear of the board. I created a spreadsheet of the values and have attached a screenshot.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Suggests q 708 and Q709 are faulty - procedure is to remove them from the board to re-test - what are the part numbers on those two?
            EDIT - I see you have posted the part no.
            Probably one of these
            http://www.alldatasheet.com/datashee...D/FDD5N50.html
            • gustagen
              • May 2011
              • 86
              #26
              I thought the values for Q708 and Q709 looked suspicious. I will report back when I've located my soldering iron and desoldering braid for testing again off the board.
              Does my testing indicate that fusible resistor F601 is also faulty? I've attached a photo for help with identification. I haven't had any luck finding it by Googling the text "ICP250 4A00SMT" printed on its side. The closest I came is this TV repair blog post, which features an "ICP250 3A00SMT."
                Yes, that fuse resistor is blown due to shorted out MOSFET.
                • gustagen
                  • May 2011
                  • 86
                  #28
                  Great, sounds like I have some parts to order.
                  The blog post I mentioned earlier suggests TWW5JR15E as a substitute for ICP250 3A00SMT. Note the differing digit on the part numbers, "3" rather than "4" on this TV's ICP250 4A00SMT. I haven't been able to locate specs on this fusible resistor.
                    It's this part (search ICP):
                    4A rated = 0.11 ohm.
                      Great job finding the spec Tom.
                      • gustagen
                        • May 2011
                        • 86
                        #31
                        Thanks, Tom! According to that spec sheet ICP250 4A00SMT is 250V, 4A, 0.11 Ohm.
                        Before your post, I chatted with a Digikey representative and he offered this TWW5JR10E as a possible alternative. It is rated at 5W and 0.1 Ohm. Does this look like what I need?
                          Only problem is it's not fusible, I'm not sure if that will matter too much though as it will likely only move the failure from that resistor to the main fuse.
                          The lead spacing is correct, but the replacement device is a little wider by 4mm. Do you think you could still fit it in?
                            Personally, I'd consider one of these devices:
                            http://www.digikey.com/product-detai...MCT-ND/2813098
                            If a 0.1 ohm resistor carries 4A max, it will dissipate 1.6W. This device is fusible and can handle 2W. The TV should use under half an amp for the backlight (@400V) as it's a fairly modern, efficient LCD TV. So I reason this device should be OK, especially as it provides the fusible option. Inrush is probably provided by the main NTC thermistor, so it's not a necessary feature.
                            • gustagen
                              • May 2011
                              • 86
                              #34
                              I like your suggestion of the fusible resistor vs. the one I had offered. I should have no problem fitting an axial lead component in place of the existing radial one.
                              I admit I'm quite out of my element at this point... Any suggestion as to which MOSFETs I may need? I found this list at DigiKey and noticed some differences in the specs.
                              I will attempt to re-read the part numbers on the defective MOSFETs and report back.
                                If you get the part # we can look up the specifications and find an equivalent device.
                                  Try using Alcohol to remove the flux off the body then you may be able to read the numbers on it.
                                  • gustagen
                                    • May 2011
                                    • 86
                                    #37
                                    I've attached a macro photo of Q709. As far as I can tell, it says:
                                    1K32CB
                                    FDD
                                    5N50
                                    A DigiKey rep was unable to cross reference that number. I understand the lowercase script 'f' indicates a Fairchild part.
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      #38
                                      in post 16 gustagen said
                                      The eight transistors you've circled all seem to have the same part numbers. They are all very difficult to read because they seem not to have been stamped hard enough for all digits to be clear, and are coated with a shiny, gummy substance. Using a magnifying glass and piecing the part numbers together from each one, I'm confident they say:
                                      1K32CB
                                      DD
                                      5N50
                                      from that I said post25
                                      Which suggests one of these?
                                      http://www.digikey.com/scripts/dksea...eywords=DD5N50
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        Selldoor's URL didn't work, but it is here
                                        http://pdf1.alldatasheet.com/datashe.../UTC/5N50.html
                                        Sometimes when looking for part numbers, the first line is not always the actual part number. I, too, tried 1K32CB first but couldn't find anything.
                                        --- begin sig file ---
                                        --- end sig file ---
                                        • gustagen
                                          • May 2011
                                          • 86
                                          #40
                                          I had previously reported the second line of text as DD, instead of FDD.
                                          I found this page at Fairchild Semiconductor which seems to indicate the top line of text refers to factory and date codes.
                                          EDIT: Looks like retiredcaps beat me to this!
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Flaku_34
                                            Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                                            by Flaku_34
                                            Introduction:
                                            Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                                            04-18-2024, 12:47 PM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • ameenameen
                                            How to force on PSU philips DPS-119CP (photos inside) TV PSU
                                            by ameenameen
                                            So problem is i have a faulty motherboard and i want to install a universal one , i could not find a power on pin , do i need to short 3,3v standby to ground ? and which pins are for power on the backlight and dim
                                            01-16-2024, 04:02 AM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
