phillips 42PFL7432d/37 remove T-con board
  • CR Designs
    • Dec 2012
    • 430
    I'm trying to remove the inverter board on this Phillips 42" TV #42PFL7432d/37 . But I can't get the connecter loose on the inverter board Need some help ,can some one tell me how this connecter comes loose. I don't want to break it. See pictures it is the blue connecter that is circled.
    inverter board has a bad IC.
    Re: phillips 42PFL7432d/37 remove T-con board
    That is the Backlights inverter board, not T-CON board. It is slipped in cable, just make sure to pull it straight out.
    • CR Designs
      • Dec 2012
      • 430
      Thanks budm !! I met inverter board,I don't know why I said T-con board.So if I got your answer right there is nothing to release,just pull the cable out.
        That is correct, just pul it STRAIGHT out, and when you nsert it back in, be sure to go staright back in or you may damage the exposed conductors if you wiggle it in the socket, those conductor tends to lift off the cable.
        • CR Designs
          • Dec 2012
          • 430
          Thanks budm, I got it out.
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • advant
            by advant
            02-03-2020, 12:25 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
