Sony KDL40S2000 TCON board issue...
    Re: Sony KDL40S2000 TCON board issue...
    He needs to show good close up pictures around the connector of the T-CON so we can see this fuse. I never seen T-CON with resetable fuse before.
      I am suggesting the fuse was inadvertently replaced with a resettable fuse instead of a permanent fuse.
        That is what I think or just very poor soldering joints, pictures will tell us what is gong on.
        • lenny1972
          • 16
          • Italy
          here a picture of the tcon board fuse that has been replaced..
          hope it can helps
            Hmm -- hard to tell -- I have seen orange resettable fuses before -- however, the best way to tell would be to install it in the TV, measure voltage on top end with TV working, then measure it as it starts giving problems or gets worse and see if there is a drop. Actually, measure the bottom too, because then we can rule out PSU, main board and cabling.
              Agree with TOM suggestion in post 25, that will be the easiest test to do.
              • lenny1972
                • 16
                • Italy
                #27
                I see..Just to be more precise:
                - the fuse is not orange but dark brown
                - the TCON board is already installed in the TV
                In order not to damage the TV or myself, i want to be sure and avoid any mistake, so I intend to do as follow:
                - I put the multimeter on DC 200
                - I have to find a negative point on the TCON board
                - I put the black tip of the voltmeter on the negative (on the board) and the red tip at the top end of the fuse and see which is the value when the TV works well
                - I repeat what above when the TV starts going wrong and see if there is a difference
                - I repeat the measure with the same negative but with the bottom end of the fuse to see if there is a voltage drop (before and after TV showing the problem)
                Now the hardest part.... how can I find a negative point on the board?? May I use any other negative point of the TV (for example the negative of the power supply board, that it's easier to find??)
                Sorry for my "stupid" questions but I want to be sure not to do any other damage
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  I normally use a ground screw closest to the measuring point. That is, you can use a ground screw on the t-con.
                  --- begin sig file ---
                  --- end sig file ---
                    And setting to DC20 will give one extra digit of resolution.
                    • lenny1972
                      • 16
                      • Italy
                      #30
                      Ok, I'll check it out and let you know the readings
                      • lenny1972
                        • 16
                        • Italy
                        #31
                        Something strange on the fuse....Below the readings:
                        TV working properly:
                        Black on TCON grounded screw and Red on Fuse BOTTOM = 4.94 VOLT
                        Black on TCON grounded screw and Red on Fuse TOP = 4.50 VOLT
                        TV NOT working properly:
                        Black on TCON grounded screw and Red on Fuse BOTTOM = 4.98 VOLT
                        Black on TCON grounded screw and Red on Fuse TOP = reading varyimg from 4.07 to 4.70 VOLT !!!!
                        A strange think happens when I did a second readings...I've noticed that pushing with the red pin of the tester on the bottom soldering of the fuse the problem disappeared..!!!! So I tried to use just the red pin not attached to the tester..and the problem fix...
                        It has to be a poor/cold soldering of the fuse on the TCON )))))))
                        May I try to fix the join by just putting the solder tip on the joint or do I have to desolder the fuse and solder it again?!?!
                          I would suspect a failed fuse -- simply replace the fuse for longest reliability.
                          • lenny1972
                            • 16
                            • Italy
                            #33
                            But how can I find the fuse value or type?
                            Can you help me in identifying the right one?
                              Since the fuse has been replaced incorrectly, and given the board takes in 5V (usually 2.5~3A at 5V), I'm going to estimate a 4A fuse.
                              http://www.digikey.com/product-detai...84-1-ND/615045
                              • lenny1972
                                • 16
                                • Italy
                                #35
                                Ok. Do you think that I have to take a SMD fuse ( like the one you suggested me) or can I take something bigger in order to be easier to solder??
                                If a SMD component is needed can I buy this product?
                                http://www.ebay.it/itm/Fuse-10-pcs-S...1#ht_500wt_689
                                It seems to be the same item of your link...
                                When soldering the fuse on the board do I have to be aware of something specific (i.e. solder temperature, fuse position, etc..)?? Sorry but I'm really a newbie...
                                • eclectric
                                  Sony Bravia KDL-70W850B T-CON board / software update issue
                                  by eclectric
                                  Hi, I'm hoping someone can help me with this issue before I give up on this TV.
                                  In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
                                  Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
                                  I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
                                  05-23-2022, 01:25 AM
                                • Soulzink
                                  Samsug washing machine. Power supply DC41-00189a board issue
                                  by Soulzink
                                  I am trying to fix a samsung washinmachine power supply main board.
                                  I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                  Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                  The power supply board reference is the following: DC41-00189a
                                  I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                  04-19-2025, 06:26 AM
                                • thelankanguy
                                  Sony KD-55X9000F TCON Issue
                                  by thelankanguy
                                  The TV shows a black screen with no image.
                                  TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                  Later both ribbons were disconnected and TCON voltages were tested.
                                  12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                  There is also a short to ground in this circled inductor.
                                  Is this a TCON issue or something else ?...
                                  12-13-2024, 12:27 AM
                                • cheeky2
                                  Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                  by cheeky2
                                  For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                  See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                  01-08-2024, 05:56 AM
                                • Asraf Atb
                                  by Asraf Atb
                                  01-27-2025, 05:02 PM
