hello, this sony kdl46ss4100 has me stumped, it has a solid green power light, which goes on and off with remote, but there's no picture just black screen, no menu, nothing, while checking it, I discovered that when I unplug cn303 which is bl on etc., I get red then green then blue then red green blue striped screens in a loop, I think it's stuck in burn in mode but can't see a menu to adjust, when I plug cn303 back in it goes back to black screen, have tried unplug and replug power, have tried 3 different a boards 2 different tcons and 2 different power suppys, meaning same board models just that many boards, all were from where a lot of techs. tell folks to shop at, not new boards but were guaranteed, haven't tried an inverter board but it just didn't seem like the problem, thanks.
sony kdl46s4100
Tags: None
Re: sony kdl46s4100
You must make sure the TCON and main boards can work with your panel model.
So they all can be good but just not compatible or you just tried a wrong combination (wrong version main but right TCON or vise versa)
But this model it seems all mains should work and there are about 14 different TCONS that will work with it as well.
What is your panel model?Last edited by drpj23; 01-22-2013, 10:18 AM. -
Re: sony kdl46s4100
its LTZ460HB10, tried these tcons one is original other is not, number on white sticker: K220468B08EE 010886 AND E2204P8J09ZB 012935, plus tried one other that was sent back, thanks for the help.Comment
Re: sony kdl46s4100
Mains:
Part Number
1-857-092-41
MFR Part Number 1 Sony 1-857-092-41 (or 21 or 11)
Board Number(s)
SO40FHD 07452-3
48.71H01.031
55.71H01.411G
Part Number (Look for 2204T on sticker)
LJ94-02204T
Board Number(s)
FS_HBC2LV2.4
Substitute Parts
1-857-044-21
LJ94-02204G
LJ94-02217G
LJ94-02217H
LJ94-02217J
LJ94-02204P
LJ94-02275E
LJ94-2297D
LJ94-02204H
LJ94-02204L
LJ94-02217B
LJ94-02833C
LJ94-02221JComment
Re: sony kdl46s4100
no, no backlight when plugged in, will try to do pictures if I can figure out how to upload, I have/tried the 2204p and 2204g both act the same.Comment
Re: sony kdl46s4100
That model has 2 versions (incompatible - not interchangeable) of main "A" board and Power "G" Board, and 3 possible panels, all with different T-Con boards. 2 versions of the panel are interchangeable with each other, one is not.
I'm guessing you may not have correct versions of boards/have a mis-matched boards problem.Comment
Re: sony kdl46s4100
ok, good info., I have gotten the same symptoms with each combo I've tried so far, do you think it would have done anything different?Comment
Re: sony kdl46s4100
I've tried two i 857 092 41 11 boards, now have two 41 boards, tried both the 41 boards with the two tcons I have that are 2204g and 2204p, I sent the two 11 boards back and another tcon that I tried, get the same exact symptoms with each combo, I can put the full number of the boards if you need it, thanks for the help.Comment
Re: sony kdl46s4100
the originals are 2204P and 5571H01411G, a strange thing on the 41 A board they sent me, it has two extra capacitors by the cable out connector.Comment
Re: sony kdl46s4100
with cn303 bl on unplugged I get backlights with the red green blue screens flashing, plug it back in and just get black screen, can't get a menu to adjust, seems like it's stuck in test mode.Comment
Re: sony kdl46s4100
also have't tried a different lvds connector cable but I got 12 volts at the tcon side.Comment
Re: sony kdl46s4100
A good question to ask too....are all the voltages in respect to their legends?
And, is it possible to see a pic when you turn the TV ON? (Since you said there was no backlight and flashlight or lightsource is needed)
If so, the balancer board (inverter) needs replacement since it is not sending a feedback signal and the main is telling it to shut off (or no BL_ON command) otherwise the fact you have lines appear on the screen indicates the TCON is probably functioning correctly (but that is why I want to see them) and so if none of the above, focus on the main (as said earlier).Last edited by drpj23; 01-23-2013, 11:49 AM.Comment
Re: sony kdl46s4100
If so, the balancer board (inverter) needs replacement since it is not sending a feedback signal and the main is telling it to shut off (or no BL_ON command) otherwise the fact you have lines appear on the screen indicates the TCON is probably functioning correctly (but that is why I want to see them) and so if none of the above, focus on the main (as said earlier).Comment
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Channel: Schematic Requests ONLY!
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... -
This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 05:27 AM
This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...09-06-2024, 05:30 AM
This specification for the Sony VAIO SVE1413XPN Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVE1413XPN boardview and SVE1413XPN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony...09-06-2024, 05:27 AM
- Loading...
