sony kdl46s4100
    • 12156
    • U.S.
    sony kdl46s4100
    hello, this sony kdl46ss4100 has me stumped, it has a solid green power light, which goes on and off with remote, but there's no picture just black screen, no menu, nothing, while checking it, I discovered that when I unplug cn303 which is bl on etc., I get red then green then blue then red green blue striped screens in a loop, I think it's stuck in burn in mode but can't see a menu to adjust, when I plug cn303 back in it goes back to black screen, have tried unplug and replug power, have tried 3 different a boards 2 different tcons and 2 different power suppys, meaning same board models just that many boards, all were from where a lot of techs. tell folks to shop at, not new boards but were guaranteed, haven't tried an inverter board but it just didn't seem like the problem, thanks.
  • drpj23
    • May 2012
    • 528
    Re: sony kdl46s4100
    You must make sure the TCON and main boards can work with your panel model.
    So they all can be good but just not compatible or you just tried a wrong combination (wrong version main but right TCON or vise versa)
    But this model it seems all mains should work and there are about 14 different TCONS that will work with it as well.
    What is your panel model?
      • 12156
      • U.S.
      Re: sony kdl46s4100
      its LTZ460HB10, tried these tcons one is original other is not, number on white sticker: K220468B08EE 010886 AND E2204P8J09ZB 012935, plus tried one other that was sent back, thanks for the help.
      • drpj23
        • May 2012
        • 528
        Re: sony kdl46s4100
        Mains:
        Part Number
        1-857-092-41
        MFR Part Number 1 Sony 1-857-092-41 (or 21 or 11)
        Board Number(s)
        SO40FHD 07452-3
        48.71H01.031
        55.71H01.411G
        Part Number (Look for 2204T on sticker)
        LJ94-02204T
        Board Number(s)
        FS_HBC2LV2.4
        Substitute Parts
        1-857-044-21
        LJ94-02204G
        LJ94-02217G
        LJ94-02217H
        LJ94-02217J
        LJ94-02204P
        LJ94-02275E
        LJ94-2297D
        LJ94-02204H
        LJ94-02204L
        LJ94-02217B
        LJ94-02833C
        LJ94-02221J
        • drpj23
          • May 2012
          • 528
          Re: sony kdl46s4100
          So do you have backlight without disconnecting that connector? (I suppose you do when you do disconnect?)
          Could you take pics of the colored lines? and the back of the TV (all the boards in other words)
            • 12156
            • U.S.
            Re: sony kdl46s4100
            no, no backlight when plugged in, will try to do pictures if I can figure out how to upload, I have/tried the 2204p and 2204g both act the same.
            • drpj23
              • May 2012
              • 528
              Re: sony kdl46s4100
              I am suspecting your main but the lines may be a clearer indication.
              Use the manage attachments feature to upload. Files cannot be greater than 2mb or 2k x 2k I believe.
                • 12156
                • U.S.
                Re: sony kdl46s4100
                I can't seem to get a good picture, I think it's this cheap camera, not enough focus but I don't see any obvious burns or bad caps etc.
                • randtek
                  • Oct 2011
                  • 280
                  • US
                  Re: sony kdl46s4100
                  That model has 2 versions (incompatible - not interchangeable) of main "A" board and Power "G" Board, and 3 possible panels, all with different T-Con boards. 2 versions of the panel are interchangeable with each other, one is not.
                  I'm guessing you may not have correct versions of boards/have a mis-matched boards problem.
                    • 12156
                    • U.S.
                    Re: sony kdl46s4100
                    ok, good info., I have gotten the same symptoms with each combo I've tried so far, do you think it would have done anything different?
                    • randtek
                      • Oct 2011
                      • 280
                      • US
                      Re: sony kdl46s4100
                      Did you keep track of EXACTLY which boards were the originals from the set?
                        • 12156
                        • U.S.
                        Re: sony kdl46s4100
                        I've tried two i 857 092 41 11 boards, now have two 41 boards, tried both the 41 boards with the two tcons I have that are 2204g and 2204p, I sent the two 11 boards back and another tcon that I tried, get the same exact symptoms with each combo, I can put the full number of the boards if you need it, thanks for the help.
                          • 12156
                          • U.S.
                          Re: sony kdl46s4100
                          the originals are 2204P and 5571H01411G, a strange thing on the 41 A board they sent me, it has two extra capacitors by the cable out connector.
                            • 12156
                            • U.S.
                            Re: sony kdl46s4100
                            haven't tried a inverter board but it didn't seem like the problem.
                              • 12156
                              • U.S.
                              Re: sony kdl46s4100
                              with cn303 bl on unplugged I get backlights with the red green blue screens flashing, plug it back in and just get black screen, can't get a menu to adjust, seems like it's stuck in test mode.
                                • 12156
                                • U.S.
                                Re: sony kdl46s4100
                                also have't tried a different lvds connector cable but I got 12 volts at the tcon side.
                                • drpj23
                                  • May 2012
                                  • 528
                                  Re: sony kdl46s4100
                                  Well what I provided all have used the panel model given.
                                  But I do think there is a combination issue at hand.
                                  Could we get pics of the screen (colored lines) please?
                                  And why wouldn't the other psu's work? Different pinout?
                                  • drpj23
                                    • May 2012
                                    • 528
                                    Re: sony kdl46s4100
                                    A good question to ask too....are all the voltages in respect to their legends?
                                    And, is it possible to see a pic when you turn the TV ON? (Since you said there was no backlight and flashlight or lightsource is needed)
                                    If so, the balancer board (inverter) needs replacement since it is not sending a feedback signal and the main is telling it to shut off (or no BL_ON command) otherwise the fact you have lines appear on the screen indicates the TCON is probably functioning correctly (but that is why I want to see them) and so if none of the above, focus on the main (as said earlier).
                                      • 12156
                                      • U.S.
                                      Re: sony kdl46s4100
                                      just a black screen with cn303/bl on plugged in, can't see anything with flashlight, no menu, just black. With cn303/bl on unplugged, no lines, just the solid red green blue and r g b w striped screen, that is the test mode it's stuck in, I guess, can't hardly get pics. of screen it has no base and unstable to move with back off, thanks.
                                        • 12156
                                        • U.S.
                                        Re: sony kdl46s4100
                                        could it be the inverter even if I can see no activity with flashlight?
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                          09-06-2024, 05:30 AM
                                          Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
