sony kdl46s4100
  • nomoresonys
    • 12276
    • U.S.
    #61
    Re: sony kdl46s4100
    or test mode solid green red n blue then striped screen loop.
      Re: sony kdl46s4100
      OK, I see what you mean, at least it is putting out something. So right now the T-CON and the main board are the original one or the replacement one.
      • nomoresonys
        • 12276
        • U.S.
        #63
        Re: sony kdl46s4100
        yes, original main and tcon are in now.
          Re: sony kdl46s4100
          Notes; the color looping mode may be due to the input is in PC input mode (I have seen this mode in Dell monitor when it does not see the video signal from PC, then it will go into standby mode a couple minutes later). So try using the remote to change the input source. I myself never seen this color looping in TV before, may be someone else in this fourum may have seen them.
          • nomoresonys
            • 12276
            • U.S.
            #65
            Re: sony kdl46s4100
            get normal reading on bl on from 2 pin on power supply with cn303 unplugged, with cn303 plugged in get 0.6 and 1.7 power on and off never goes to 5 v, get same 0.6 and 1.7 with both main boards, is it correct to think that both boards are not putting out enough volts to bl on and are both bad, even tho they both measure exactly the same?
              Re: sony kdl46s4100
              As I explained earlier, the BL-ON pin has the built-in pull up resistor to provide >3v, the main board will have switched transistor to take that voltage at BL_ON PIN to GROUND to keep the BL_ON LOW which will cause the backlights to be off, no need to worry about the backlights at this point sicne we can have backlights by not having BL_ON connected to the main board, the problem right now is the main board is not functioning.
              If both board keep the BL_on pin low when turn on, then yes, your main board is bad. Now the problem is that this TV may use error signal from the T-CON to keep the backlights off, not all SONY use that signal. Too bad that this model does not use blinking LED to show the error codes. I will have to dig further into the service manual. In the mean time, can you get me the LCD panel model number as printed on the sticker so I can see the spec of the T-CON to find out if it uses the ERROR pin or not?
              Looping color screen would indicate to me that the main board is not functiong for sure.
              • nomoresonys
                • 12276
                • U.S.
                #67
                Re: sony kdl46s4100
                for sure, why they left out codes is strange, the panel model is LTZ460HB10.
                  Re: sony kdl46s4100
                  This is the low end model, so no error code function. Let me look up the spec of the panel next.
                  From servie manual:
                  IMPORTANT:
                  The units in this manual DO NOT contain a self-diagnostic function. If an error occurs, the TV will not stay on. It is our recommendation that if a repair
                  is required for this set, the technician should bring both the A Board and the G Board to the customer location.
                  Description of LED Indictors
                  The units in this manual DOES NOT contain a self-diagnostic function.
                  Follow-up; I look at the service manual, they do not use any error signal from the T-CON.
                  • nomoresonys
                    • 12276
                    • U.S.
                    #69
                    Re: sony kdl46s4100
                    From servie manual:
                    IMPORTANT:
                    I get 0.6 and 1.7 power on and off never goes to 5 v, so I think even tho both main boards measured exactly the same, they must both be bad, Im thinking I should try a mainboard from someone other than shop jimmy.
                      Re: sony kdl46s4100
                      The number (PCBA -Printed Circuit Board Assembly) as printed on the barcode sticker matches your original board?
                      • nomoresonys
                        • 12276
                        • U.S.
                        #71
                        Re: sony kdl46s4100
                        pretty close, original is 5571H01411G841082E1J03G, the other is 5571H01411G819263E3J03C, and shop jimmy swore up and down that 1 857 092 11 would work, but tried 2 of those, thanks.
                        • nomoresonys
                          • 12276
                          • U.S.
                          #72
                          Re: sony kdl46s4100
                          theres a guy on another forum that had the same exact symptoms, he ordered bad mainboard, but the next one he got solved the issue.
                            Re: sony kdl46s4100
                            That is good to know then.
                            • nomoresonys
                              • 12276
                              • U.S.
                              #74
                              Re: sony kdl46s4100
                              was trying to save this from the landfill, but not sure its worth it, heard nothing but bad things about sony and specially the kdl line.
                              • nomoresonys
                                • 12276
                                • U.S.
                                #75
                                Re: sony kdl46s4100
                                thanks a lot for the help, I think I'll try 1 more main.
                                • nomoresonys
                                  • 12276
                                  • U.S.
                                  #76
                                  Re: sony kdl46s4100
                                  does anyone know what voltage I should get from just the main board bl_on switch with cn303 unplugged, so I know for sure this main board is bad, if it was explained before, I got lost in the technical terms, thanks for any help.
                                    Re: sony kdl46s4100
                                    Well, if you read my explanation, we already forced the backlights to come on and you still do not see pictures on the screen, so you have bad main board or bad T-CON regardless what the BL_ON signal is.
                                    • IK74
                                      • Mar 2014
                                      • 7
                                      Re: sony kdl46s4100
                                      Sorry for jumping on one year old thread. I have same Sony KDL-46S4100 and same symptoms as "Nomoresonys". also ordered second replacement A board which did not work... I researched several threads online and this one has the most helpful information. But I have additiona question:
                                      I noticed there is a DC voltage about 57V between grounds of primary and secondary circuits on the Power board (there is 57V DCV on the big left&middle heatsinks (they are connected) and small heatsink on the right (which is connected with general ground of the entire chassis or primary AC input.
                                      It looks like leveled half wave from the 120V AC input from the bridge rectifier.
                                      Is this a normal design or sign of failure ?
                                      Btw, did you resovle your problem Nomoresonys? Thanks
                                        Re: sony kdl46s4100
                                        "I noticed there is a DC voltage about 57V between grounds of primary and secondary circuits on the Power board (there is 57V DCV on the big left&middle heatsinks (they are connected) and small heatsink on the right (which is connected with general ground of the entire chassis or primary AC input.
                                        Is this a normal design or sign of failure ?" That is because you are using the wrong ground ref point when you work in the Primary side of the circuit, you have to use the negative leg of the main filter cap as the Ground ref point for the primary side of the circuit.
                                        • Peter Chiu
                                          Banned
                                          • Dec 2012
                                          • 145
                                          Re: sony kdl46s4100
                                          Same problems after change main Board and TV fixed ..........Sony 1-857-092-21 Main A Board for KDL-46S4100 Panel Sticker Number: LTY460HB08
                                          PS: This TV no needs to update sofeware.
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                            This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                            09-06-2024, 05:30 AM
                                            Sony VAIO SVE1413XPN Notebook E Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVE1413XPN Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVE1413XPN boardview and SVE1413XPN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony...
