LG 42LG70 42" LCD 1080p - Won't turn on/no picture&sound
  • blair
    Hi there,
    I just recently bought a used TV from my friend for $80, he let me know that there was some sort of power problem with it, it would work alright for a while then just randomly turn off, and then not turn on for a long while.
    When you press the remote power button (or the TV power button), it does the red blinks like it warming up/turning on, then goes to the blue (means its on), however no sound or picture comes up on the screen.
    It worked great all day the first day I had it, and now it won't even turn on at all. I was told that sometimes it just stays off for a day or two so we will see if it will turn on tomorrow, however, this must be fixed.
    I have done some research on what the issue may be, I have come across alot of information and I am not very experienced with TV/monitor-related repair, however I am well experienced in computers, software and hardware, and I am planning on doing the repairs myself rather then taking it into a shop.
    I was reading that it might be a capacitor on the power board, so I opened up the back of the TV and none of them are blown up, exploded, or bulging from what I can tell. However, I am planning on replacing all of them on the power board anyway, so I was wondering if anyone knew where I can get affordable ones for my board? I live in Canada so they would have to be able to ship to Canada.
    If the capacitor repair does not work, my next option would be to completely replace the power board.. this is just what from what I've read online and I will have one of my friends take a look at it tomorrow.
    If you've read all the way down to here I really appreciate it and please give me some input on this problem!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: LG 42LG70 42" LCD 1080p - Won't turn on/no picture&sound
    Digikey.ca is well respected and has great service. Shipping will cost $8, but you get it quite quickly.
    However, before you order anything, check to see if the power board has 5V DC standby.
    --- begin sig file ---
    --- end sig file ---
    • blair
      The only power boards I found for my model were on ebay and some 'parts something' (forget the name) website... I was just going to make sure the part # matched the one in my TV.
      I am confused on what you mean by 5V DC standby...? Would this be something related to the caps I can put on the board?
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        Post clear pictures of your boards.
        • blair
          Working on the pictures, don't have a good camera so I will have to borrow my buddies and I will let you know.
          How easy is it to kill a component via static electricity? Mainly TV components?
          I'm going to stop by a store and see if I can pick up a multimeter or something like that...
            Touching the metal frame of the TV occasionally during service is sufficient to prevent static damage in the vast majority of cases.
            • MisterD
              • Oct 2012
              • 668
              To answer your question about 5V DC Standby Check this out, it may be of help to you.
              • retiredcaps
                • Apr 2010
                • 9271
                Note: This is not aimed at blair, but after seeing budm get frustrated again, I thought I would add some suggestions.
                I think if budm changed his sig file to include a link to his guide, he wouldn't be so burnt out answering questions. At a minimum people asking for help should read through it completely and ask clarification questions.
                This approach is more
                "Give a man a fish and you feed him for one day.
                Teach a man how to fish and you feed him for life.
                This approaches scales. Giving one on one help burns out many regulars (including myself).
                It is also why I changed my sig file to give clear examples of what we need in terms of picture clarity and composition, information, etc. If people don't bother to read it, I will reciprocate.
                Not everyone agrees with my approach and I have been called condescending with this method, but I refuse to answer anymore "how do I test a fuse" questions after I have written about it countless times.
                  Thanks retiredcaps, I juat add the link.
                  • pajdek
                    Lenovo Y700-17ISK turn on and off
                    by pajdek
                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                    09-20-2023, 02:49 AM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                  • robante15
                    Acer Aspire 4520 won't turn on after reboot
                    by robante15
                    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                    If I remove the...
                    04-06-2024, 06:50 PM
                  • masoksian
                    Dell latitude e7470 not turn on .power buton on off and Run Power problem
                    by masoksian
                    I am dealing with the problem of turning on and off my Dell e7470 notebook.
                    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                    The system does not turn on, there is no post.
                    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                    The problem continues in the same way.
                    I tried to turn on the Fn key, nothing came to the screen....
                    02-15-2025, 12:08 PM
                  • Ledgurra
                    MacBook Pro A1425 it doesn't turn on
                    by Ledgurra
                    hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
                    thank you all
                    11-09-2025, 06:07 AM
