sanyo dp42740 no startup no powerlight
  • awyatt2
    • Feb 2012
    • 407
    • america
    anyone got a manual for this tv, only a little over a year old. voltages are not marked on ps. darfon powersupply, good news is a pabnasonic screen. no relay click when you try to start it only when you plug it in all fuses ok, all caps check out good,all diodes, resistors and the mosfets check ok. thinking maybe digital board but need sm to confirm.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: sanyo dp42740 no startup no powerlight
    What is the voltage on the PFC capacitor in the power supply?
    Does the power supply have the correct output voltages?
    Muh-soggy-knee
    • awyatt2
      • Feb 2012
      • 407
      • america
      yes the power supply is working it has all voltages as it should it's hung in on with no video i need the print on the mainboard.
        But what voltage do you get on the PFC cap? We need that number to know if the PFC Voltage booster is working or not.
        • awyatt2
          • Feb 2012
          • 407
          • america
          bud the power supply is working all the voltages are there, where they should be the tv is stuck in on position. when you plug it in it tries to start up went sour while i was out and took some other board out. get a dim glowing screen no pic all voltages are where they should be. this one is under extended warranty and hasnt made a year yet. i would have attemped repair if i could have found a service manual and dont think the manual is out if so no one has it. lest none of the pay sites do. this one is not power supply, leaning toward main board, i will know tomorrow service man will be here.
          • awyatt2
            • Feb 2012
            • 407
            • america
            confirmed control board or panel, tech just left. extended service contract paid off on this one. anyway i have it to play with.only wish i had the print on the cntrl board so i could really get it fixed. it is surface mount but no bga arrays on it.
            • Scuse
              • 50
              When you say the control board was the problem. Is that the same as the logic board? Also does yours have the analog and digital tuner boards separate but connected? That's how mine is set up
              • johnboy1313
                • Nov 2012
                • 1959
                awyatt, did the new control board fix the problem? I have the same set with the same issue.
                • BMCappelletti
                  Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                  by BMCappelletti
                  Hi everyone.
                  Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                  Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                  Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                  02-18-2025, 12:22 PM
                • survivalbloke
                  Macbook A1398 - no startup chime, no boot, but have fans and CPU warm
                  by survivalbloke
                  Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?
                  06-14-2023, 11:45 AM
                • EthanMai
                  DELL PRECISION 3440 SFF X4N41 10th ST-3L0GZB3 25Q256 Slow startup, needs cleaning.
                  by EthanMai
                  DELL PRECISION 3440 SFF X4N41 10th 25Q256 Slow startup
                  ST-3L0GZB3
                  needs cleaning.
                  Please help me clean up the slow startup dump if you have time. Thank you....
                  07-05-2024, 11:43 AM
                • cj_reha
                  Mystery 80s Sanyo cap - perhaps polymer?
                  by cj_reha
                  Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                  01-06-2023, 09:24 AM
                • grimacelord
                  Sanyo DP42740 - Powers On, No Video - Missing 15/25v
                  by grimacelord
                  TV original came to me with no power, no LED, no sign of life whatsoever. I took some initial voltage measurements and found the SN board had multiple shorted components on the board and I found a replacement cheap enough so I replaced the SN board. I also bought and installed a repair kit for the main power supply board. Now, the TV shows some signs of life, but it still isn't there yet. I scoured through all of the threads here about this model, but haven't found anything similar to this particular problem. Here is what it is doing now:
                  When I plug in the TV to power, I hear the...
                  03-19-2019, 07:21 AM
