Issue with 50PC3d LG
  • gornati
    • 27
    • Brazil
    Hi all, this is my first post, regarding an issue with mine LG 50PC3D.
    Here is a video of the issue.
    And some pics also!
    http://www.youtube.com/watch?v=bBwp2-VcoP4
    Need some help diagnosing the problem, read some about Z sustain, Y etc...
    Looks like power source?
    Thanks in advance.
  • gornati
    • 27
    • Brazil
    Re: Issue with 50PC3d LG
    Just a little bit more information.
    The issue started with some red pixels flickering on the screen only visible if looked closely.
    Then after a few months, got no brightness from time to time.
    Now it is like that all the time.
    Doesnt smell bad, no smoke no loud noises.
    • awyatt2
      • Feb 2012
      • 407
      • america
      looks like zsus
      • gornati
        • 27
        • Brazil
        should we get some more opinions before i buy the board?
        • gornati
          • 27
          • Brazil
          very disencouraging... Z sustain board is about $179.00 + 139.00 shipping = $318.00 + 70% import taxes and fees, +- $318.00 + $210.00 = $528.00, here in Brasil i can get a new 50" for about $800.00.
          I would really appreciate more opinions!
            It is possible to replace the IPM (integrated power module, also known as hybrid) for close to $30. But it requires very good desoldering equipment.
            • gornati
              • 27
              • Brazil
              found it on ebay for $19.00, now looks much better.
              • gornati
                • 27
                • Brazil
                is this the power supply? any easier to replace the whole power supply?
                  No, it is a component on the Z-sustain which fails.
                  It contains an array of MOSFETs and IGBTs (power transistors.) Unfortunately, due to it being an IPM, you cannot replace the individual components, the whole module must be replaced.
                  This is definitely a Z-sustain failure. The panel is not being discharged and sustained properly.
                  • gornati
                    • 27
                    • Brazil
                    so, the part to be replaced is the Z sustain board?
                    could you please confirm if this is the board we are talking about?
                    http://www.ebay.com/itm/261151105143...84.m1423.l2649
                      That is a board for a Pioneer plasma TV and will not be suitable.
                      You should replace the device under the large heatsink on the Z-sustain board. The picture you linked to is a similar board, X-sustain is same as Z-sustain. On an LG plasma the Z-sustain is on the right hand side of the plasma panel, looking from the rear.
                      • Sevenqi
                        • Jul 2011
                        • 292
                        Please find out the z-sustain board part number in your TV before search the ebay.
                        The z-sustain is in the right side of your tv (from back).
                        • awyatt2
                          • Feb 2012
                          • 407
                          • america
                          is this the tv you posted a lg 50pc3d this zsus(link-ebay) is a pioneer. in order to work it must be the exact same board.you cant take any zsus and put in any tv. it may cross ref but you had better be sure.
                          • gornati
                            • 27
                            • Brazil
                            well, looks like the part number is the same.
                            http://www.discount-merchant.com/LG-...-p/1005292.htm
                            or am i wrong?
                            • gornati
                              • 27
                              • Brazil
                              or this one...
                              http://www.discount-merchant.com/LG-...-p/1002390.htm
                              • gornati
                                • 27
                                • Brazil
                                i am opening the tv again and will get some pics and part numbers.
                                  But it is not the right board. That is for a Pioneer plasma TV. Pioneer made their own plasma panels a few years ago, along with custom drive electronics. It is completely different and will NOT work.
                                  • gornati
                                    • 27
                                    • Brazil
                                    Ok, just disassembled the TV and noticed some stuffed capacitors on the power board (at least i think it is the power board!
                                    Please check the 2 pictures. one are the 3 stuffed capacitors the other one is the Z sus board with the right part number "6870QZC004B".
                                    So the question is, could the issue be the power board? part #6709900020A.
                                    Thanks for the patience guys!
                                      That's the power board, yes.
                                      You have a very common issue with this set which is failed capacitors.
                                      But they are not yet giving trouble because the Z-sustain is the actual failed part. They would however cause problems in a few weeks to months ahead of time, so they should be replaced as well.
                                      Your picture is of the Z-sustain and the IPMs are under the large heatsinks.
                                      • gornati
                                        • 27
                                        • Brazil
                                        I live in Brasil, very expensive shipping rates and extremely high import fees and duties... i am talking about 110% aproximately!
                                        The board is like $83 + $35 shipping ( the lowest i found on ebay) plus 110% on import fees, taxes and duties, we will talking about $250.00, should i repair this monster, 720p, 6 years old, or go for a new set, with 1080p, 3d and the works, for about $1000?
                                        Any inputs would be great.
                                        • MakNCheese
                                          ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                                          by MakNCheese
                                          I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                                          Symptoms:
                                          • Severe lag across the system, including BIOS navigation.
                                          • Slow boot times and unresponsive performance in Windows.
                                          • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                                          • No error messages or BSODs, just extreme sluggishness.
                                          What I've Tried:
                                          • Replaced
                                          06-04-2025, 12:48 AM
                                        • code share
                                          Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                          by code share
                                          I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                          Here's what I've tried so far:
                                          • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                          • Booted successfully on AC power only with the battery disconnected
                                          • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                          • Battery
                                          04-21-2025, 12:50 PM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
                                        • shahnld
                                          Lenovo legion 5 pro startup issue
                                          by shahnld
                                          Good day Experts
                                          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                          Yesterday, 12:31 PM
