Samsung 400PN 40" without image (Backlight ok)
  • afurucho
    • Brazil
    Dear sir, I need help.
    The Samsung Syncmaster 400PN turn lights on in the background but no picture appears.
    The source had blown 470uF capacitor, the output of 12V. I took to replace all capacitors originals.
    The TV turns on, turns on the lights but nis with a high noise at the power supply, do not know the origin.
    I did all the measurements of voltages at input connectors from the logic board are all OK.
    Someone can give me some suggestion?
    Thanks sirs.
    Adriano
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Samsung 400PN 40" without image (Backlight ok)
    Did you order high quality capacitors with low ESR?
    • afurucho
      • Brazil
      Most capacitors that are used Huang brand 105 ΒΊ C. Thanks for the contact.
      • selldoor
        Slow Learner
        • 7870
        Welcome to the forum-
        We can usually help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
        Examples of what is needed
        https://www.badcaps.net/forum/attach...7&d=1280167246
        https://www.badcaps.net/forum/attach...6&d=1280167246
        https://www.badcaps.net/forum/attach...4&d=1280167246
        It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
        • learnmore
          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
          by learnmore
          Hello Community!
          CASE DETAILS
          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
          Tried inserting firmware on USB and left it in for a few hours, but no change
          03-03-2024, 09:49 AM
        • wolf1976
          samsung ue40d6100 has no backlight no sound and image
          by wolf1976
          hi to all
          on the above model of samsung i have the faults i have told already on the title
          iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
          any idea from someone what can i measure so i can find the problem ?
          the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
          11-17-2024, 01:02 PM
        • mi16rs
          SAMSUNG UE32M4005AW BACKLIGHT OK BUT NO IMAGE
          by mi16rs
          Hi i have a samsung UE32M4005AW that have backlight but no image , i have changed the main board but still the same problem , so i guess it as a fault on the panel board , could some one help me on this ? thanks...
          02-08-2024, 03:19 AM
          09-07-2024, 05:50 AM
        • C152Heavy
          by C152Heavy
          Summary for TL-DR readers:
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
