Vizio GV42LHDTV No Digital Channels
Re: Vizio GV42LHDTV No Digital Channels
Hi, I realize this is a really old thread, but I thought I might be able to add some info to it.
First, I want to thank everyone else who posted here.
I am working on a Vizio VX37L. The tuner portion of the main board looks pretty much like the one on the GV42L. And I have the same problem. The autodetect completes the analog channel search, but does not even begin to search the digital channels. The progress bar does not turn yellow at all.
However, my problem is more intermittent in that it did work one time, then found about 70 channels. But later that day the TV only had a blue screen and no channels worked except the one analog channel. After that the autodetect never worked again on the digital search.
I tried the various suggestions posted here, but I don't have a remote. It seemed like I could do most everything I needed with the buttons on the side of the unit. The "unchecking" the individual channels could not be done. The checks were grayed out.
Based on 102mm's post, above, and the excellent video, I opened the unit and checked the 1.25v regulator. It was rock solid.
So then, as a last resort, I popped open the RF enclosure. Inside was what I assume is a really tiny potentiometer. I rotated it back and forth multiple times, probably like 20 times, vigorously. I made sure to note what position it was in, and put it back to that position.
This seemed to fix the problem, but I can't say for sure it wasn't something else I may have touched. The digital channel search progress bar immediately had a tiny portion turn yellow, and after about 2 or 3 minutes it found 70 channels. I reassembled the TV and after 24 hours, it is still working.Comment
Since I can't put up photos yet, I should mention, the potentiometer I exercised was a small metallic one, which appears like a small rivet or small screw-head. I don't think it would be recommended to exercise the variable inductors. They look like rectangular cans with a dark adjustment screw inside the middle. Those screws don't make direct electrical contact, so there would be no benefit to rotating those.Comment
The cans with the dark adjustment screws are actually coils with a ferrite bead in it (no physical contact) and as you adjust the dark screw or ferrite bead the number of Micro-Henries or Milli-Henries change in a tuning circuit. DON'T adjust these.Comment
I can now post photos, so here they are. I also included photos of the regulator that "102mm" replaced in his video.
Cover over main board.
Main board exposed.
RF enclosure.
RF enclosure with lid popped off.
Don't adjust the inductor can (left of pot in photo). Only the tiny potentiometer.
Closeup of potentiometer (center of photo).
Don't adjust inductor (left side of photo).
Main board showing regulator marked AMC 1117 F0632J
Regulator marked AMC 1117 F0632J
Yes, I mentioned that in the post before yours. Maybe you didn't see it. But thanks for the confirmation.Comment
I realize this is an old posting and no one will probably see this but hey nothing ventured nothing gained. I have a 2007 Vizio GV42L HDTV too which I love with same tuner issue ie won't scan for digital, just the analog. I tried all the suggested fixes; the last one being the take TV apart (a challenge) and wiggle the wee pot as suggested by loudhvx. No change. Tried it again. Still nothing. I give up. I think I am going to try the external tuner solution that FriedFarmer I think talked about having as they are cheap ($25-$30...much cheaper than taking TV to repair shop) and give you features not included with TV like DVR functionality.Comment
Well here's some more crap to try: https://www.fixya.com/support/t23906...ed_getting_allComment
Assuming...7 Photos -
by dicky96Hi Guys
I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
He also has an LG TV, so three screens in the bar
I installed three Satlink ST-6503 DVB-T Modulators
This model https://www.aliexpress.com/item/32916553905.html
These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to... -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by Xristakis795hi to all
I have the above TV and it presents the following problem
when i tune in and search for terrestrial digital channels he finds them normally
but I hear only sound I do not see image and I have to see with mpeg4 decoder external device
what could be wrong? - Loading...
