Vizio GV42LHDTV10A - Stays on 10 seconds - then shuts off
  • drpj23
    • May 2012
    • 528
    Upon plug in, the backlight will stay on 5-7 seconds then go out along with the TV going back to standby 3 seconds later.
    The TV came on with the blue screen with "No Signal" Text floating.
    I have detached inverters and TCON and problem still persists.
    The main had one bad regulator (DU4) which was an adjustable but with that replaced the problem is still here.
    Anything else to look for on these mains?
    Vizio's guide for DC-DC converters just checked U1 (Dual FET) pin 1, 3, 5, 6, 7, 8 had 5.162v on them (good?) and then checked the regs.
  • Cosmo66
    • Nov 2012
    • 87
    Re: Vizio GV42LHDTV10A - Stays on 10 seconds - then shuts off
    Did you remove a heatsink?
    • drpj23
      • May 2012
      • 528
      There is a clip for what I presume to be the audio driver that is removed, but that is it.
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        What made you think that the regulator was bad?
        What voltages were you seeing on all of the regulators?
          Was it in the PC VGA input mode? Does it do that if you use Video source input mode?
          • drpj23
            • May 2012
            • 528
            The regulator was under the 1.25 difference, that is why it was replaced.
            And it is (budm), it is now on another input and is currently on as I type.
            Is that an actual setting or a fault with that input?
              That is normal, it is just like computer monitor that will go in to standby mode if it does not detect video signal from PC, and if you leave the TV in tuner mode but do not have antenna or cable attach, it will also go into standby mode after 10 seconds to minutes, most TVs are setup that way now.
              • drpj23
                • May 2012
                • 528
                Oh, well I am familiar with the auto-off features but I have never had one do it that fast lol.
                I'll consider it lesson learned.
                • riko 656
                  Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                  by riko 656
                  I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                  Laptop Model:
                  • Model: Lenovo Legion Slim 5 16APH8
                  • GPU: NVIDIA GeForce RTX 4070
                  • Main BIOS chip size: 32MB
                  • VBIOS chip size: 16MB
                  Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                  What I Have Tried So Far:
                  1. I
                  11-04-2025, 05:14 AM
                • chaos-theory
                  Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                  by chaos-theory
                  I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                  Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                  03-14-2025, 05:37 PM
                • riki_22
                  ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                  by riki_22
                  I’m working on an ASUS B5402CEA notebook.
                  B5402CEA_MB_R2.2
                  HA4YT LA-L861P
                  REV:1B
                  The board powers on, fan spins for a few seconds, then it shuts down by itself.
                  I suspect the BIOS might be corrupted.
                  Could someone please check and clean (repair) the attached BIOS dump?
                  I’ve also attached a few photos of the motherboard for reference.
                  Thanks in advance for your help!
                  11-03-2025, 04:38 AM
                • APOPAP
                  Panasonic National NV-M3 VHS Camera shuts down after some seconds
                  by APOPAP
                  Hello everybody,
                  First post here. I have been reading posts here for some time now, but today I made my first account and post.
                  The same question is also posted on another site, here it is:
                  Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                  I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                  08-25-2025, 10:12 AM
                • tec3000
                  Sony LED 65X9005A shuts down after few seconds - looking for help
                  by tec3000
                  Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                  I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                  03-20-2024, 07:29 AM
