Testing & Repairing a Y-Buffer board
  • titan2782
    • Dec 2012
    I know that the upper and lower Y-Buffer boards have something wrong with them. When they are plugged in I get a D12V error code. When I leave them off, there is no error.
    What exactly goes bad, the surface mounted ICs? How do I test these boards (other than plugging them in)? Do I need to replace the ICs to repair the board? That's an obvious, kind of dumb question but I have to ask.
    I'm not to keen on soldering surface mount IC's with 60 pins but I also don't want to sped $150 on new boards.
    The boards are
    LJ41-02760A (upper)
    LJ41-02761A (lower)
    The TV is a Sanyo DP42746.
    I've already replaced the bad caps on the main power board and the Y-SUS.
    I've been through this thread https://www.badcaps.net/forum/showthread.php?t=18707 and it was helpful including the links.
  • Mt.Man
    • Jun 2012
    • 53
    Re: Testing & Repairing a Y-Buffer board
    Look over each IC closely if they don't have heat sinks attached. Lots of times in the center of the IC on the bad one you might see a hole or burnt mark.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • repair-it
      Need advice testing a samsung power supply board with scope
      by repair-it
      I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
      07-12-2025, 11:00 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
