I can't adjust the Va and Vs voltages to spec. Turning the pots doesnt change the voltage neither higher nor lower. The spec voltage for Vs should be 210 but is 160, the Va voltage is 46 but should be 54.Any ideas anyone?
Samsung PN42c430 dim picture
Re: Samsung PN42c430 dim picture
Most common this is actually the X-main (on Samsung at least), not the Vs/Va. Check your meter battery is good just in case this is the problem.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
What is that green cap bottom left corner of the board with the pots on.
Often the diameter is relative to the size of the circle on the board.
Is it an original cap? has this board been worked before - do you know the history
What are the two caps bottom right.Please upload pictures using attachment function when ask for help on the repair
Originally posted by selldoor View PostWhat is that green cap bottom left corner of the board with the pots on.
It should stay up for a few seconds if the TV turns off; where are you testing it, on the PSU?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
All measurements are taken with a digital meter connected to chassis ground and Vs post.
Initial measurement 28mV
Energizing the PSU - 173V dropping to and stabilizing around 10V.
Power up the panel - 173V dropping to and stabilizing around 155V.
All this with the Y sus cable connected.
Now, you want me to disconnect the Y sus cable? At the PSU or at the Y sus board?
Disconnect at the PSU. If the Vs rises to the correct level, then it indicates an issue with the power supply (being unable to supply the power demanded.)
Have you also tried with a fully white screen to see if Vs drops off even more?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Try connecting it to your computer and display a mostly white screen. This draws the most power.
This doesn't appear to be as such an adjustment problem, as it can go higher with no Y-main. I suspect that marked blue capacitor.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostTry connecting it to your computer and display a mostly white screen. This draws the most power.
