Samsung PN42c430 dim picture
  • happbear
    • Dec 2012
    • 9
    • canada
    I can't adjust the Va and Vs voltages to spec. Turning the pots doesnt change the voltage neither higher nor lower. The spec voltage for Vs should be 210 but is 160, the Va voltage is 46 but should be 54.Any ideas anyone?
    Re: Samsung PN42c430 dim picture
    Most common this is actually the X-main (on Samsung at least), not the Vs/Va. Check your meter battery is good just in case this is the problem.
    • gilly1984
      • 751
      You prob no more than i do but are you turning the correct pots? I remember tom66 commenting on one and it had pots for va/vs and a couple of other for something else. I forget now though.
      Do NOT touch heatsinks when testing for voltages as they may be LIVE!
      • happbear
        • Dec 2012
        • 9
        • canada
        My meter batteries are new. The measurements were taken at the post Va and Vs on the main power board.
        • selldoor
          Slow Learner
          • 7870
          What is that green cap bottom left corner of the board with the pots on.
          Often the diameter is relative to the size of the circle on the board.
          Is it an original cap? has this board been worked before - do you know the history
          What are the two caps bottom right.
            Does Vs rise when the Y-main is disconnected?
            • happbear
              • Dec 2012
              • 9
              • canada
              Dont know the history, all looks original, checked replacement boards on ebay and the bords look identical to mine.
              • happbear
                • Dec 2012
                • 9
                • canada
                Vs drops to almost 0 when Y-main is disconnected
                  It should stay up for a few seconds if the TV turns off; where are you testing it, on the PSU?
                  • happbear
                    • Dec 2012
                    • 9
                    • canada
                    All measurements are taken with a digital meter connected to chassis ground and Vs post.
                    Initial measurement 28mV
                    Energizing the PSU - 173V dropping to and stabilizing around 10V.
                    Power up the panel - 173V dropping to and stabilizing around 155V.
                    All this with the Y sus cable connected.
                    Now, you want me to disconnect the Y sus cable? At the PSU or at the Y sus board?
                      Disconnect at the PSU. If the Vs rises to the correct level, then it indicates an issue with the power supply (being unable to supply the power demanded.)
                      Have you also tried with a fully white screen to see if Vs drops off even more?
                      • happbear
                        • Dec 2012
                        • 9
                        • canada
                        Ok disconnected
                        Energized the PSU - meter spikes to 193V emits three peeps while briefly displaying 1000V and then dropps rapidly to 0V aprox.
                        • happbear
                          • Dec 2012
                          • 9
                          • canada
                          Originally posted by happbear
                          Ok disconnected
                          What do you mean by white screen?
                            Try connecting it to your computer and display a mostly white screen. This draws the most power.
                            This doesn't appear to be as such an adjustment problem, as it can go higher with no Y-main. I suspect that marked blue capacitor.
                            • happbear
                              • Dec 2012
                              • 9
                              • canada
                              Thanks Tom, I had to make room for the Xmas festivities and remove the tv of the kitchen table. I will look at it again in the new yearr. Thanks for your help and happy Holidays
                                09-07-2024, 05:50 AM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • JJAAMM
                                by JJAAMM
                                Problem
                                07-06-2023, 06:01 AM
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • Dodgethis
                                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                by Dodgethis
                                Hello all,
                                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                09-11-2024, 07:39 AM
