Panasonic TH-42PZ77U SC board repair 7 blinks
    Re: Panasonic TH-42PZ77U SC board repair 7 blinks
    You should test between the tab and each of the two pins.
    The tab is drain, one pin is gate, one pin is source.
    The same fet on my board failed on as the AVSForum one, so I would suspect that one.
    • johnboy1313
      • Nov 2012
      • 1959
      Since I have so little experience doing this, I decided to test all seven with the red on the lifted leg and the black on base. In this configuration I got
      1=541
      2=541
      3=013
      4=541
      5=541
      6=290
      7=290
        013 --- you found the dead one.
        • johnboy1313
          • Nov 2012
          • 1959
          Ok, I'll get the other leg too. Does it need to be lifted from the board too?
          • johnboy1313
            • Nov 2012
            • 1959
            Cool. Do you think I should keep testing the rest of the transistors? Do you see a problem with #'s 6 and 7 being so different than the other 4?
              #3 is definitely bad. If you cut both lower pins, try the TV and see if it works. Then replace the fet.
              • johnboy1313
                • Nov 2012
                • 1959
                So, I kinda got ahead of myself and turned the set on before connecting SC2 and SC20. I shut it back off and unplugged it from the wall. How long should I wait before trying to connect those plugs? Is there a method to discharging the unit?
                • randtek
                  • Oct 2011
                  • 280
                  • US
                  #28
                  Usually a few minutes is long enough. I have been told that pressing and holding the power button for 10 seconds will help discharge too. I don't know if it really does or not.
                    Check the Vsus voltage. If it's under 20V I'd say it's fine. It'll decay while the TV is off. You may get a tiny spark.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      It came on but the screen seems to be split horizontally down the middle. Below the line, the black part of the screen is very black. Above the line, the black part is kinda grey. The menu is clear on the top and bottom. I disconnected the SD board from the panel before I realized I didn't need to. Is there an adjustment for this? Do i need to play with the ribbon connections again? Have you ever seen anything like this? There is nothing wrong with the picture anywhere on the screen, just a difference in the top half and bottom half.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Never mind this post. I thought I had it fixed but I was wrong. It's still darker on the bottom.
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          So, the darkness was caused by me. When I originally pulled the SD board, I didn't see the middle flex connector. When the board slid out of the SC, it pulled the plastic housing off of the pins on the SD board. I carefully put the housing back on but damaged the top most pin doing so. I then pulled the pin off of the board when I was trying to straighten it. I know, I can be a real klutz sometimes. Long story short, I got the pin straightened out and reattached to the board, but it showed considerably more resistance from the pin to the trace on the circuit board than the rest of the pins on that clip did to their own traces. I ran a jumper from the pin to the back of the board where the trace came through. Now when measured from the back of the board to the pin on the front, I saw 1.4 ohms, just like all of the other pins. I was really proud of my fix. Well, just now as I was taking these pics, I decided to test the resistance of the top pin on the SU board compared to its trace. It was considerably more than 1.4 ohms, so much that I got an overload with the meter set at 200 ohms. I cut my jumper and powered on the set and bingo, no more darkness. I guess I'm lucky I didn't burn anything up.
                          Now I just need to figure out where to find a 5N2307 transistor, how to remove the bad transistor without damaging the board, and how hard it is to install the new one.
                            Yeah, I damaged that connector when I fixed the TH-42PZ70BA too, so I used a bit of (relatively weak) glue to secure it.
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Originally posted by rayrod81
                              The part number is B1DFKM000002 or 5N2307. Here is thread from AVS Forum with some info for you. http://www.avsforum.com/t/1001318/ma...#post_17876879
                              I ordered two Panasonic B1DFKM000002 this morning. $15.42 total including shipping. Now, how hard is it to remove that thing from the board? Is the entire back of the transistor soldered down? If so, I doubt my little 30W iron will get it out.
                              EDIT, picture below stolen from link above.
                                Yes, entire back is soldered.
                                Just apply lots and lots of heat, and push it slowly and carefully off the pad. Be very careful not to damage the pad.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  What's the trick to removing this FET? I've got a 100w, a 140w, and a monster 180w soldering gun and I can't seem to get this thing hot enough to move. Do I just put the tip of the gun on the thing and hold it until it's hot enough?
                                    Lift the two pins, apply heat to the tab, and push on it. It will come off after some time. 100W max. 140/180W could damage PCB.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Got it. That's the new one. Third from the top.
                                        Great. Does TV work ?
                                        • johnboy1313
                                          • Nov 2012
                                          • 1959
                                          Haven't got that far yet. It's dinner time here.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • Biruslapio
                                            Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                                            by Biruslapio
                                            Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                                            It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                                            It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                                            02-16-2021, 09:44 PM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            I happened several times, in the search for help from the web, to consult this very interesting forum.
                                            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                            Having said that I come to the gist of my post on the forum as the title suggests.
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
