Sharp LC-47SB57UT will not power on
  • johnboy1313
    • Nov 2012
    • 1959
    I just picked this unit up. It will not power up at all. The fuses are not blown on the power supply.
    At the connector above, from top to bottom,
    0V
    0V
    0V
    0V
    0V
    GND
    GND
    GND
    GND
    GND
    N/A
    3.3V
    3.3V
    3.3V
    3.3V
    0.79V
    0.79V
    GND
    GND
    GND
    0V
    0V
    1.4V
    4.97V
    4.97V
    The two pics above are of the same connector with wires and without, it is the other end of the previous connector. From top to bottom
    4.97V
    4.97V
    1.4V
    0V
    0V
    GND
    GND
    GND
    0.79V
    0.79V
    3.3V
    3.3V
    The connector above from left to right
    GND
    1.49V
    1.49V
    0.15V
    1.49V
    N/A
    GND
    1.49V
    1.49V
    N/A
    Re: Sharp LC-47SB57UT will not power on
    This is not a Sharp TV. This is a UniHan TV, with the Sharp logo stuck on it. Sharp are selling their name... and it doesn't even use a Sharp panel.
    The problem is most likely the main board, this seems to be the most common issue with this chassis (which is more and more prominent.) If you have standby power but no main power, that's where I'd look. And I'd think it's firmware/eeprom, so pretty hard to fix.
    • johnboy1313
      • Nov 2012
      • 1959
      Do you know how I could get the power supply to come on all the way to see what happens?
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        You might get more members helping you if you posted your pictures using
        manage attachments.
          The PS pin looks to be the one you need to look at.
          Try forcing that to 5V using 5VSB with a 1k resistor.
          • randtek
            • Oct 2011
            • 280
            • US
            To force the power supply on, you will need a couple of resistors. I usually use 100 Ohm resistors for this, but it is not critical, anything between about 47 Ohms and 1K Ohms is probably fine. Unplug the TV from the wall. Disconnect the cable that goes from CN903 on the power board by unplugging it from the main board. On this cable you have just disconnected, run one resistor from 5V (yellow wires) to On/Off (Blue wire), and another from 5V to PS On (white wire). Make sure this cable/resistors cannot accidentally short against anything, Plug the TV in to the wall power outlet. You should be able to read all of the power supply voltages with the unit connected in this manner. You will probably see the backlights lit too.
            • johnboy1313
              • Nov 2012
              • 1959
              manage attachments.
              I wasn't aware of that. Out of curiosity, can I ask why it matters?
              • johnboy1313
                • Nov 2012
                • 1959
                Thanks guys.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  The 0.79v on the 12v rail is odd. It could be a short on the mainoard.
                  If it is still like that when the PSU is powered on, while disconnected from the chassis, then there is an issue with the PSU.
                  Muh-soggy-knee
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    I'm pretty sure I followed the instructions. I used 2, 220 ohm resistors because those were the first ones I positively ID'd in the bin. Red, red, brown, gold. I confirmed it with my meter. I installed them per your directions and got a steady fluctuation from ~2.0V - ~3.5V at all four pins involved.
                    Long story short, when plugged back in, I still see no power at ON/OFF, either of the 12V red wires, or either of the 24V orange wires.
                    EDIT- in the pic it looks like the resistors may have been touching. They were not.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Here's another shot
                        On some TVs, PSON needs to be brought low; try connecting through 220 ohm to ground.
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          With the resistors in the pins below, I now have 0V at PS_ON, white, and 5V at DIM, blue but still nothing at either 24V or 12V.
                          EDIT- Ok, I see what I'm doing wrong. Green is ON/OFF not blue. I'll try again and post back in a second. My bad.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            I tried 5V to ON/OFF with PS_ON to ground and again with PS_ON to 5V same results as above.
                              OK, can you check what the voltage at PSON is each time, just to be sure the resistor is the right value. It might actually be a PSU problem -- that's something that can be diagnosed...
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                With ps_on to 5v both ps_on and on/off fluctuate back and forth from 2.5v to 3.5v. With ps_on to ground, ps_on is at 0.0v and on/off is at 5v. There is no click that I've become accustomed to hearing at power on. The LED on the front never lights up.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  Resistor 1
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    Resistor 2
                                      So, if PSON is varying, check if 5VSB is too.
                                      • johnboy1313
                                        • Nov 2012
                                        • 1959
                                        Yes it is.
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • gavenb
                                          Sharp LC-80LE661U 80 inch
                                          by gavenb
                                          Hi folks!
                                          I have a LC-80LE661U that had some interesting issues.
                                          Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                                          I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                                          11-12-2023, 02:05 PM
                                        • SONY_E-WASTER
                                          Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                          by SONY_E-WASTER
                                          Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                          The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                          then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                          does...
                                          12-26-2021, 05:46 PM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
