DVR problem
  • preacherman
    • Nov 2012
    DVR problem
    I have a DTVPal DVR that was made by Dish Network. They stopped producing and servicing this unit.
    The problem I have is that the picture will intermittently distort like it's receiving a weak signal. After so many of these the unit will lockup, and need to be reset. The signal strength is good, and I don't see anything obvious on the mainboard or power supply board.
    I tried heating the boards to see if the problem would get worse, but it didn't. I tried disconnecting the antenna to see if it would do it when just watching a recorded movie, it still does it.
    I've not checked to voltages yet.
    Anyone know what the problem might be?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: DVR problem
    Do you live on a bus route or on a road used by taxis or near a neighbour who is into cb.
    I used to have a set with a settopbox and whenever a bus went past it used to go blocky but recovered.
    • dtvPALfan
      • Feb 2014
      Re: DVR problem
      As I am typing mine just did it again!
      Mine started doing this in December and will lock up twice or more DAILY.
      Did you ever find a fix for this?
      I am not techno savvy, but I am handy and can follow instructions.
      ie: replaced a capacitor on a board before (not on the DTVPal) a $2 repair versus a $200 replacement.
      Note: Just before this started happening (about a month) I would hear it running while in standby mode. Assuming it was the fan?
      It has never been connected to ethernet, or anything other than the antenae cable and the TV to have received any "updates" although it does give me that message occassionally.
      I have had this since it was first released and have used it heavily, with minor glitches here and there that have worked themselves out. This one, is the most annoying and the most alarming.
      It happens during live TV as well as while watching back recorded shows (so no this is not transmission interference)
      My guess it is hard drive related or power/capacitor related (may have/be overheating for fan related issues?)
      Any assistance is appreciated.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Re: DVR problem
        If its not external interference then we need good clear pictures of the board/s inside to get an idea what to test. Intermittant problems are often difficult to solve.
        • Tvbob
          tvbob
          • 204
          Re: DVR problem
          Run it with the cover off,The hdd is always writing data I have used an usb laptop cooling fan on several dish network dvr"s
          • Caleb
            Smokin IC's
            • Feb 2013
            • 645
            Re: DVR problem
            Mine was acting in a very similar manner, I was thinking it might be firmware related as it almost always happened between 5 and 6 pm. My other thought was a read error from the hard drive causing a reboot.
            Liberating magic smoke one part at a time
            • jaaa1976
              HP EliteDesk 800 G4 Mini PC -There is a problem with the security device on the unit
              by jaaa1976
              Hi everybody !
              I bought this pc from ebay with error - There is a problem with the security device on the unit
              please fix my bios.
              Model: HP Elitedesk 800 G4 mini PC (65w)
              serial no. 8CC93326J4
              PRODUCT NO. 4KW04ET#ABU
              32- 16mb bios attached
              Thank you so much...
              12-19-2024, 06:48 PM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
            • perzyk23
              Lenovo T580 - LCD Panel problem - error 0288
              by perzyk23
              Good morning,
              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
              10-25-2024, 12:42 AM
