I just received a free 20" Symphonic LCD TV (WF20L6) it didn't come with a remote so I have to use the menu buttons on the TV to navigate through the setup. I got to the channel setup and it only goes from Video 1, Video 2 and then skips to channel 60 and that's it. The lady who gave it to me said it was broken but didn't say how...so i'm assuming this is what she meant. Any ideas? There is no Channel 3/4 switch on the back so it's not that.
Symphonic wont turn channels
Re: Symphonic wont turn channels
Hook up an antenna to it and autoprogram the digital channels. You'll have to navigate the menu to do this via the buttons but it should be easy.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
Yeah I already tried that using a digital converter box and again using an HD antenna but still no go....i'm scratching my head here.Comment
This is not a digital tv - try connecting a video via composite or svideo in.
Handbook:Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
by pajdekHello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
by RdeveLabsTo all the members here...
Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But... -
by dicky96Hi guys
I couldn't really find a section on the forum for this question so I guess I will put it here
I do a lot of work in one of the local apartment hotels (an apart-hotel they call them here)
Mostly I am maintaining the equipment in the 'TV' room or at the pool bar
Anyway, I have a problem with the system in the TV room - most of this was a system I 'inherited' off the previous technician who no longer lives on the island
Basically they have (see pic it probably explains it better) the following system. The UHF cabling is daisy chained... -
by robante15Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
If I remove the... -
by masoksianHi everyone,
I am dealing with the problem of turning on and off my Dell e7470 notebook.
The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
The system does not turn on, there is no post.
I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
The problem continues in the same way.
I tried to turn on the Fn key, nothing came to the screen.... - Loading...
