First plasma, LG 42PC5D. Sound but no picture. Help me make sense of this.
    Re: First plasma, LG 42PC5D. Sound but no picture. Help me make sense of this.
    That is actually a pretty nice scope! Only limitation is its memory is I think 2.5k samples, but that's only useful if you want to look at several subframes. With most plasmas, all you need to see is if a particular waveform is there. Just make sure you use a 400V rated (or more) 10X probe with it. You do not want to blow up the input amplifier/attenuator section! Turn a dual channel scope into a single channel one . How much did you pay for it, if you don't mind me asking?
    • johnboy1313
      • Nov 2012
      • 1959
      I borrowed it from a friend at work. Unfortunately it is only rated for 300V max. I found an older (early 90s) meter/scope on Craigslist that I might buy for $100. According to the manual I found online its capable of inputs up to 400V and 1Ghz
        Using a 10X probe with a 400V rating makes the signal only 40V at the scope, so you can use the oscilloscope with it. My Rigol is 300V rated but can survive a 1000V transient, so brief overvoltage is usually fine. Just either use a 10X fixed probe or be very careful not to move the switch from 10X to 1X.
        • johnboy1313
          • Nov 2012
          • 1959
          Where am I actually connecting the leads of this scope? What am I looking for? What am I setting the scope to?
            Can't see the pictures but you're usually looking for a test point marked "Waveform". Can you use Manage Attachments to upload higher res images in case it is named something else?
            • Cosmo66
              • Nov 2012
              • 87
              I would take a DMM real quick and probe around the y and z board looking for shorts. I've had 3 of these IPM failures and they all failed short to gnd.
              You can also remove the y and z boards, the IPM pins stick through the back and should be labeled. If you measure a short from one of the voltages to ground you know its bad.
              I wouldn't recommend trying to change the IPM unless you have a good heat gun, just replace the whole board
              • johnboy1313
                • Nov 2012
                • 1959
                Wouldn't there be blown fuses if something was shorted to ground? Both y and z sus boards get warm to the touch when the unit is powered on.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  I'll have to look into the higher res images. Right now I can't even load pictures to the site. I've had to resort to using photobucket.
                  • Cosmo66
                    • Nov 2012
                    • 87
                    Probably but not always
                    • Cosmo66
                      • Nov 2012
                      • 87
                      The IPM's don't always fail short to ground. But as someone stated earlier, this is by far the most common cause of failure in the LG plasmas. The IPM's are garbage. When they fail, you get sound with no picture.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        I found a point on the y buffer that says waveform. The problem is that I have next to no idea what I'm supposed to do. I know it makes me sound really ignorant. I do have experience with a scope. I took two years of part time EET classes at the local junior college but that was at least three years ago. What am I setting the scope to? Other than the waveform point, where do I touch for the other point? CH 1 to waveform, EXT TRIG to to ground? Seriously, I can do this, but not without some guidance.
                        Are any of you able to post pics to your profile? I can't even find my profile album. It's like I've been blocked or something.
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          I started a second thread regarding scoping the ysus and zsus. For the sake of those who might have this same issue in the future, I'm coming back to this original thread. Here's the other thread.
                          https://www.badcaps.net/forum/showthread.php?t=24715
                          At this point, I am suspecting the y buffer board again. I know someone said that a bad y buffer would cause different symptoms, but hear me out.
                          I just unplugged the y buffer board from the y sus and powered on the unit, which resulted in the exact issue as when the board was plugged in. Now I know that this doesn't confirm a bad y buffer. However, my thought is that it does confirm that the set will display the same symptoms with the buffer removed. If I had removed the board and the unit. Would no longer power up, that would suggest, at least to me, that the buffer was not part of the problem. This is promising, is it not?
                            Do you still have the scope?
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              No, I took it back but I asked him if I could borrow it again if needed and he said that was fine.
                              • ghiotom
                                • Oct 2012
                                • 41
                                Did you check the IPM on the Ysus board for shorts? The fact you aren't even getting a dim image I would think would point to the Y sus board.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  There are no blown fuses on either y or z sus. The boards both get warm when powered on and I scoped both boards and was told that the waves looked fine. Everything, except the lack of glow, suggests the ysus is working fine.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    I just read through this again. It took a second to set in. No, I didn't check the IPM for shorts. I will and will report back.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      First picture, these are the pins on the IPM from the back of the Ysus board. The pins in the yellow circle are the same pins in the yellow circle in the second pic. Of the pins in the yellow circle, they all show to be connected to ground though only the one says ground, I suspect that they are all supposed to be grounded. As for the rest of the pins, unless they say GND right next to them, there were none shorted to ground.
                                      However, this thing, the grey can with the red vertical stripe, whatever it is, labeled L202 on the back of the board, is shorted to ground. I have no idea if it's supposed to be or not. It's counterpart, L203 just behind it and to the right, is not shorted to ground.
                                      • johnboy1313
                                        • Nov 2012
                                        • 1959
                                        Tom66, if I can get the scope again tonight, what am I going to scope?
                                          The copper traces are all connected, so they are all supposed to be grounded.
                                          You can check to see if each buffer line is being driven (there are test points next to each line), but be VERY careful not to short them out, or the buffer will be blown up.
                                          • LEECH666
                                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                            by LEECH666
                                            Good day ladies and gentleman!
                                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                            01-19-2024, 05:46 PM
                                          • PlasMatt
                                            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                            by PlasMatt
                                            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                            09-20-2025, 06:50 PM
                                          • KYBOSH
                                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                            by KYBOSH
                                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                            No picture but you hear the TV static (white noise) playing loud and clear.
                                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                            But it seems they didn't get too far and just left it.
                                            When I first took a look I was amazed at how pristine the inside looked.
                                            Its as if the TV had been in a time capsule.
                                            Caps looked like they were just pulled off the self.
                                            Copper coils had no sign of corrosion on...
                                            02-01-2023, 11:10 PM
                                          • SluggerB
                                            LG Plasma (PDP50R10101) No picture No sound
                                            by SluggerB
                                            This is my first Craigslist freebie fix attempt. 50 inch LG Plasma TV Previous owner said over time it was struggling to turn on, it would take 4-5 times to turn on, the one day it just did entirely. I took it home and plugged it in, I her a click, then a second later another click, and nothing. Dead as a doorknob
                                            So I took the back off and check voltages. The power supply appears fine, I checked the VS, VA, and 5V voltages and they all measured correct, on the power supply board and on the display boards (Y and X boards). All the fuses are fine
                                            Following a YouTube videos...
                                            12-03-2022, 09:10 PM
                                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:30 PM
