First plasma, LG 42PC5D. Sound but no picture. Help me make sense of this.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: First plasma, LG 42PC5D. Sound but no picture. Help me make sense of this.
    Originally posted by tom66
    You can check to see if each buffer line is being driven (there are test points next to each line), but be VERY careful not to short them out, or the buffer will be blown up.
    Check with the oscilloscope? Am I just looking to see that they all look similar? Am I checking at the connections from the YSUS to the buffer or from the buffer to the panel?
      You just need to check a few, with the scope. If they are all missing, the buffer is at fault (possibly damaged by a bad panel but I've -never- heard of this on an LG.) But if even one is present you should see a glow from the panel, and the panel integrity might need questioning...
      I have never done this test myself but you should definitely see the ramp and sustain waveforms for all buffer outputs, each should look almost the same as the other lines.
      • johnboy1313
        • Nov 2012
        • 1959
        Thanks, I kind of expected that. I'll try to get the scope and report back this afternoon.
        Again, am I checking the pins at the SUS to the buffer or the buffer to the panel? I would guess the buffer to the panel.
          Buffer to panel.
          • johnboy1313
            • Nov 2012
            • 1959
            Well, I got the scope and found a wave at the very first point. However, I also bought some reading glasses today and found this when I put them on. I'm not sure how I missed it before. Obviously, someone's been here before me.
            I probed the pins and found.
            Top leg
            5.0V
            Bottom 5 legs from left to right
            6.0V
            3.2V
            0.0V
            0.0V
            0.0V
            Would a bad main board produce a similar "no picture" fault?
            Also because I'm inexperienced with plasmas sets, I decided to make this video. There is buzzing when I power on the unit but not like what was in the video posted earlier. You be the judge.
            http://s177.beta.photobucket.com/use...69E0F.mp4.html
              The top leg and middle bottom leg need to measure the same, check your probing.
              Could also be factory rework.
              Have you tried in a COMPLETELY dark room for the slightest glow... it may be very faint....
              • johnboy1313
                • Nov 2012
                • 1959
                I tried the set in the basement at night. The only light was the faint glow of the streetlight a block down coming through the window across the room.
                  Everything should be there for the plasma panel but it still doesn't seem to light.
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    I rechecked the regulator on the main board. I either misprobed it or didn't remember it right because it has 5v at the center pin now.
                    I think it's gotta be the panel. I just unplugged the ysus and powered it on and there is absolutely no buzzing before the speakers come on. Did you watch the video I made? Coul you hear the buzzing?
                      I can barely here any buzzing, but it's almost always continuous and very loud. All plasmas emit a very slight buzzing in operation.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Looks like this one has me beat. I'm not going to throw good money after bad in an effort to fix an antique anyhow. So with one last effort to hit it out of the park, I'll post this.
                        The top pin of connector P800 labeled 3.4V_ON shows 4.75V when on and 0V when off. Does that mean anything to you? I will be parting this one out with the assumption that the panel is bad if I haven't figured anything out by this weekend.
                          3.4V_ON just turns on the 3.4V output, so it's a logic signal around 0V off, 2~5V on.
                          • rayrod81
                            • Oct 2010
                            • 205
                            #53
                            If the logic board has been worked on then that could be the fault. The oscillator is what produces the signal to turn on the panel drivers. If that is not present then you would get the no picture fault. It should output a 100MHz sine wave. If that is not present then that is your problem.
                            Edit: It looks as though that might be the Main Board but it is hard to tell with out seeing the whole board. Either way I would check the oscillator on the logic board.
                              There should still be pre-discharge from the panel if it's getting the Vsetup ramps though. And the Y-sus and Z-sus won't generate the right outputs without correct timing.
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                Yeah, it's the main board. What's this oscillator look like?
                                Is this directed at me? I haven't any idea what it means. Sorry
                                  It was directed at both.
                                  The Vsetup ramp is that rising voltage captured on the scope.
                                  All other timings are correct.
                                  As far as I am concerned the control board is sending all the right signals and the Y-sus and Z-sus are properly interpreting them.
                                  Check the oscillator on the control board -- it's usually underneath the main board on this chassis.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    What's the oscillator look like? I had to bring the scope back this morning do I need to get it again?
                                      Typical appearance (left), bottom of device (right):
                                      http://www.sz-wholesaler.com/userimg...llator-701.jpg
                                      • johnboy1313
                                        • Nov 2012
                                        • 1959
                                        What am I checking it for? How am I checking it?
                                          Depends -- if you find it, post a picture. I can highlight the oscillator output pin.
                                          • LEECH666
                                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                            by LEECH666
                                            Good day ladies and gentleman!
                                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                            01-19-2024, 05:46 PM
                                          • PlasMatt
                                            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                            by PlasMatt
                                            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                            09-20-2025, 06:50 PM
                                          • KYBOSH
                                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                            by KYBOSH
                                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                            No picture but you hear the TV static (white noise) playing loud and clear.
                                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                            But it seems they didn't get too far and just left it.
                                            When I first took a look I was amazed at how pristine the inside looked.
                                            Its as if the TV had been in a time capsule.
                                            Caps looked like they were just pulled off the self.
                                            Copper coils had no sign of corrosion on...
                                            02-01-2023, 11:10 PM
                                          • SluggerB
                                            LG Plasma (PDP50R10101) No picture No sound
                                            by SluggerB
                                            This is my first Craigslist freebie fix attempt. 50 inch LG Plasma TV Previous owner said over time it was struggling to turn on, it would take 4-5 times to turn on, the one day it just did entirely. I took it home and plugged it in, I her a click, then a second later another click, and nothing. Dead as a doorknob
                                            So I took the back off and check voltages. The power supply appears fine, I checked the VS, VA, and 5V voltages and they all measured correct, on the power supply board and on the display boards (Y and X boards). All the fuses are fine
                                            Following a YouTube videos...
                                            12-03-2022, 09:10 PM
                                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:30 PM
