First plasma, LG 42PC5D. Sound but no picture. Help me make sense of this.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: First plasma, LG 42PC5D. Sound but no picture. Help me make sense of this.
    Here's the control board. I think it's been worked on too.
    • johnboy1313
      • Nov 2012
      • 1959
      Sorry it's taken so long. My interest in fixing this has dropped off a bit lately.
        That looks like a factory mod to me.
        Top right pin might be the clock.
        • johnboy1313
          • Nov 2012
          • 1959
          Back to this one. I've had a few sets on the bench this past week that kept me from parting this one out. I'm still not ready to say the panel is bad. The evidence just doesn't support it. I worked on a Panasonic plasma this week and if anything the buzz emitted from the LG is quieter than the buzz emitted from the working Panasonic panel. I will attempt to get the scope again tonight.
          I assume you are saying I should scope the top right pin. Is this correct? Is this board also called the digital board? In this link, posts 11 and 13, a member going by the name randtek outlines a procedure for testing the digital board.
            You could call this the digital board. It is essentially the same as a T-con in an LCD TV.
            Try scoping that top right pin.
            • johnboy1313
              • Nov 2012
              • 1959
              From the top right pin. I can't think of anything else but the panel.
                Can't see a problem. I would expect the panel to glow with everything it is given...
                • johnboy1313
                  • Nov 2012
                  • 1959
                  I wish I knew more about this. Everything I've read says that the output from the boards should have looked odd, due to overworking, if the panel was bad. These boards do not appear to do that.
                  I've got that Panasonic plasma that I've posted about in another thread. Even when that set would not power on, I could clearly see the panel prime, even in a lighted room. This set does not do anything like that.
                  I just don't get it.
                  • LEECH666
                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                    by LEECH666
                    Good day ladies and gentleman!
                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                    01-19-2024, 05:46 PM
                  • PlasMatt
                    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                    by PlasMatt
                    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                    09-20-2025, 06:50 PM
                  • KYBOSH
                    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                    by KYBOSH
                    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                    No picture but you hear the TV static (white noise) playing loud and clear.
                    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                    But it seems they didn't get too far and just left it.
                    When I first took a look I was amazed at how pristine the inside looked.
                    Its as if the TV had been in a time capsule.
                    Caps looked like they were just pulled off the self.
                    Copper coils had no sign of corrosion on...
                    02-01-2023, 11:10 PM
                  • SluggerB
                    LG Plasma (PDP50R10101) No picture No sound
                    by SluggerB
                    This is my first Craigslist freebie fix attempt. 50 inch LG Plasma TV Previous owner said over time it was struggling to turn on, it would take 4-5 times to turn on, the one day it just did entirely. I took it home and plugged it in, I her a click, then a second later another click, and nothing. Dead as a doorknob
                    So I took the back off and check voltages. The power supply appears fine, I checked the VS, VA, and 5V voltages and they all measured correct, on the power supply board and on the display boards (Y and X boards). All the fuses are fine
                    Following a YouTube videos...
                    12-03-2022, 09:10 PM
                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:30 PM
